ABS speed sensors in a 407
Results 1 to 10 of 10
    145
    Default ABS speed sensors in a 407
    I am going to change the ABS sensors in the front of my 407 soon . Could anyone who has done this let me know if there is anything I should be aware of before I start . Thanks in advance , Keith
    Apr 2017
    5
    I would just disconnect the battery the formal way.
    Jul 2013
    Newcastle/ central coast
    1,086
    No big dramas right side is the easiest job you will ever do the left is made easier by a cable tie ,old sensor side to the new plug side and carefully pulling it through the wheel arch it sits under the fuse box so with a bit of forethought nothing in engine bay needs to be touched the battery can stay connected because it self checks ever ignition cycle a bit of grease on the barrel of the sensor will increase life of new part. Tools req long t 30 better that Allan key two cable ties and pliers
    145
    Thanks for that . Seems like a great way simplifying the routing of the new cable . This is what makes this forum such a valuable resource . Most appreciated , Keith
    Member New2Pugs's Avatar
    Mar 2005
    40
    Quote Originally Posted by keithm View Post
    Out of interest, why are you changing them?
    1,544
    Was going to ask similarly, they are a non wearing part and as long as they maintain their magnetism and electrical connection is good?
    307 HDi wagon
    407 HDi wagon
    Jul 2013
    1,086
    Probably because they donít last as long as brake pads. Pretty common failure
    1,544
    Oh dear what I have just got then, a 407 wagon. Seriously, they are non contact ferro magnetic pickups just like the CAS, very poor if this is true. I understand the question if this is the case.
    307 HDi wagon
    407 HDi wagon
    145
    If I turn hard left I get an ABS failure alert come up . I suspect that one of the connections is being affected and changing both front sensors is a good place to start . Not expensive either . I have learnt to drive without it alarming by limiting the lock to left , quite easy to do actually but I really should change the sensor . Once I switch the car off it resets so I haven't been too concerned .Fear not Matthew about your new purchase . These cars are amazing but there are plenty of people who don"t share this opinion and that is their choice . Mine is a 2.0 HDI wagon and I couldn't think of another car I would prefer be driving
    1,544
    Fully agree, same vehicle. I suspect you are stressing the connector, the sensor itself is fine, just the ecu (ABS) is not detecting the coil resistance and alarms.
    Clean and un-stress whatever cable route it follows and retest?
    I say this as I think the electrics are their achilles heal. I have had rear lights fixed, front fogs and now the sidelights are playing up. Generally it just earthing or cleanliness, I bought a grease used in electrical work, used very sparingly on connections, its great.
    Go to ebay and look for this SANCHEM NO-OX-ID, its excludes air so no oxidisation and is conductive great on everything electrical.
    307 HDi wagon
    407 HDi wagon
