Hydraulic pump
Thread: Hydraulic pump
    Aug 2018
    Wasleys South Australia
    3
    Default Hydraulic pump
    Hi, my 1999 cabriolet 306 roof pump will run but wonít activate the roof, I replaced a hose for the rear window and when I tried raising or lowering the roof I hear the pump run but nothing happens, itís full of oil and everything works manually fine. Any ideas as to why. Thanks for any help
    1000+ Posts driven's Avatar
    Apr 2005
    1,344
    Normally need to bleed hydraulic systems
    There is probably air in the line and this is just getting compressed. So nothing works
    Don't know how the Peugeot system works but normally crack open a fitting or bleed valve to let air out.
    If unsure take to mechanic as hydraulics under pressure are dangerous
    Aug 2018
    3
    Ok, Iíll try that, thanks for your help.
    Sep 2018
    Gosford
    3
    You could try putting the roof trough the emergency closing and opening procedure a couple of times. That should bleed any trapped air out of the system. Should be in your owners manual if you need the instructions.
    Jul 2013
    Newcastle/ central coast
    1,484
    Check the roof pop switch in the join just above your head in the join on the drivers side wiring normally breaks
    Aug 2018
    3
    Ok, thanks for that Iíll give it a try over the weekend, stay tuned but it canít be much as it was working fine till I replaced the hose. Thanks again
