504 Engine Pipe
Results 1 to 7 of 7
  • 1 Post By BIGRR
Thread: 504 Engine Pipe
    Jan 2013
    Geelong
    469
    Default 504 Engine Pipe
    I have a 504 motor in my 404 Ute project
    The 504 engine pipe WILL fit (if you poke your tongue out the right way) but it is uncomfortably close to the gear change mechanism etc.
    I prefer to use it as the 404 unit is a bit on the skinny side and has the "Y" much closer to the manifold.
    Has anyone encountered "cooking" issues with this arrangement?
    Should I consider ceramic coating to lower the temperature on the surface?
    1949 Citroen Big 6
    1955 MGA1500
    1970 Peugeot 404 Utility (Resto project)
    1962 Renault Dauphine Gordini (Resto project)
    1950 Grey Fergie Tractor
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,371
    504 Engine Pipe-dsc04652.jpg NOT an answer to your immediate engine pipe problem, though slightly related.
    504 engine pipes have habit of failing (Breaking off) at the pipe to flange weld.
    I added a number of small gussets to mine after it broke off coming up the Hume MANY years ago (1978?). I added the gussets to a new replacement engine pipe and it has been there ever since.
    Good Luck.
    PS Yes this photo was hard to take!
    geodon likes this.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    9,019
    A proper 404 one has a very long length to the Y, under the floor in fact. It is the 504 one which is short.
    Quote Originally Posted by geodon View Post
    Jan 2013
    Geelong
    469
    OK.
    I assumed the shorter one was a 404
    1949 Citroen Big 6
    1955 MGA1500
    1000+ Posts Beano's Avatar
    2,933
    If there is any chance of "cooking", I would err on the side of caution. It happened to me once but I forget the details. What might alleviate it slightly is a metal heat shield in between, but I would not rely on that at all.....just as an addition in case of a very slight chance of cooking
    9,019
    Yes, one on the right is 404. the lower pipe of the 504 one has been chopped for some reason.
    OK.
    346
    In the distant past I recall that I fitted the longer of the 2 to a 504 and it gave a nice performance boost. Win!
