604 Electronic Ignition
Results 1 to 22 of 22
    Hobart
    1,496
    Hi,
    Sorry to be a pain! but I am going to have a go at putting the Electronic Ignition in the 604 over the weekend...
    I need all the info...any help would be great!
    Ben
    1989 Peugeot 405 Mi16
    2000 Peugeot 306 XSI
    1973 Peugeot 504 GL
    12,266
    Pug_405_Mi16:
    Hi,
    Ben
    i'll break into the 604 tomorrow and get pics and details
    shouldn't take too much to get int othe car after some wallace stuffed the lock on it
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Hobart
    1,496
    Thanks Sean!!
    Your a champion!
    Ben
    1973 Peugeot 504 GL
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    Pugrambo,
    Could i get a copy too please? deal
    I'm putting the new water pump in this weekend. I replaced the relay in the front of the engine bay and it turned out to be the ignition relay. So thats one less problem to be solved. dance
    cheers!
    Andrew
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
    Hobart
    1,496
    Andrew,
    It's all fun isnt it mallet . After my last 604 I swore I would never have another...and here I am again
    Oh well will I never learn
    Ben
    1973 Peugeot 504 GL
    12,266
    you forget all about the skinned knuckles, sleepless nights, hoses in "why in hell are they there" places, bolts that "why didn't they make them just a little bigger so they wouldn't snap so easy" sizes and of course the alternator position that you will all learn to love in time believe me, then when you go to wind down the rear window and the sunroof opens you will think bloody french cars
    once you are driving down the road with the wind in your hair in pure comfort
    hey even you other 1/2's will forgive you for all those moments where you said "not now dear i'm just not in the mood after playing with that stinking bloody car all day and getting no where"
    1 x 2018 3008
    May 2002
    Bathurst
    946
    Oh yes the joy of it all. It's still not as bad as changing the leads on the 505 gti .
    The wife won't let the boys near the shed while i'm working on the cars and the dog won't come near me either
    It's amazing the cars not going and it still drives me to a_drink a_drink .
    cheers!
    Andrew
    Hobart
    1,496
    Ahhh yes,
    Well I pick her up today...and after that the games will begin
    spanner spanner spanner
    Ben
    1973 Peugeot 504 GL
    12,266
    click <a href="http://au.f1.pg.briefcase.yahoo.com/pugrambo_au" target="_blank">here</a> for some pics
    now then
    from the volvo control box there are 4 wires you need to worry about
    at the end of the wire loom from the box there is a white wire and a brown wire
    white wire goes to negative side of the coil
    brown wire goes the positive side of the coil
    not far from the end there are another two wires that come out of the volvo loom from the control box
    the blue wire goes to 0.4 side of the ballast resistor
    the brown wire goes to the 0.6 side on the ballast resistor
    these are both one one side of the ballast resistor
    the other side of this you need the yellow wire number 24 from the pug wiring loom
    wire number 112 from pug wiring which is green goes to the negative side of the coil and 112A is blanked off also the bigger blue wire that comes out of the loom next to 112A is blanked off as well
    you should have a wire from the dissy that has a plug on the end of it with a spring clip on it that one of course plugs into the the other wire from the volvo box
    if you need any more help just let me know and i can walk you through the process
    now then when you go to put on you electric fuel pumps run the positive wire from the positive side of the coil
    that way the pump only runs when you have ignition on
    you can run a fuse on there as well to safe guard it if you like
    make sure you also put a "T" in the return fuel line with restriction to run any excess fuel back to tank
    you can blank the line off if you prefer but i don't do this
    if you leave it dangle fuel will run out of it
    if you leave it plugged onto the old pump it will pressurize the fuel tank
    1 x 2018 3008
    Hobart
    1,496
    Thanks Sean!
    Although the pics seems to be missing !
    Ben
    1973 Peugeot 504 GL
    12,266
    <img src="http://us.f1f.yahoofs.com/users/e9ee7283/bc/604+elec+ign/IMG_0009.jpg?bfGVuX_ARyXyIk2I" alt=" - " />
    when you click on the word "here" above it should take you to my briefcase and from there you shouold be able to click on 604 elec ign and it will take you to where there are links to the pics
    let me know if you have any trouble
    <small>[ 10 September 2003, 06:36 PM: Message edited by: pugrambo ]</small>
    1 x 2018 3008
    12,266
    ok problem fixed
    i had them in there as bmp not jpg
    you would think that i would have learnt by now
    oh well i'll put it down to doing too many things at once this morning
    1 x 2018 3008
    May 2002
    Bathurst
    946
    Thanks Sean
    Less chance of finding the smoke filled wires now whistle
    cheers!
    Andrew
    Hobart
    1,496
    Well it's here! it's been a long pain staking trip *a drive that takes 20 mins took 1 hour*
    Ben
    1973 Peugeot 504 GL
    12,266
    Pug_405_Mi16:
    Ben
    must be a sick girl
    hope you get her running well
    1 x 2018 3008
    Hobart
    1,496
    she is very sick !
    I am going to spend some time tommorow going through some of the more simple things...
    Ben
    PS i will get some photos as well !
    1973 Peugeot 504 GL
    Hobart
    1,496
    Just an update for those who are interested...
    I looks at this stage like a cam problem on the right hand bank....so we are going to take the rocker cover off over the weekend and re-set the tappets and have a bit of a look at whats going on!
    Ben
    1973 Peugeot 504 GL
    12,266
    right hand bank ??
    is this the right hand one looking from the front of the car or from the drivers seat ?
    604's have oil troubles and can have cam troubles in the left hand bank (ie from drivers seat left hand head)
    there was a fix issued for this problem and basically it entails opening up the oil gallery into the left hand head to supply more oil to the cam
    1 x 2018 3008
    Fellow Frogger! aquinian's Avatar
    WA
    604
    pugrambo:
    ______________________________
    Hi Sean,
    What is a ballast resistor and what does it do?
    On the fuel pump wiring, why not add a tachymetric relay? Otherwise your fuel pump continues to run when you engine does not start, if you leave the ignition on. Once you get your head around how they work, they are a no-brainer to wire.
    John Lane.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    12,266
    as far as i know the ballast resistor is designed to lower an operating voltage to the coil from 12 volts down to 9 volts to maintain a low voltage to the points and condenser. The ballast resistor is bypassed when the starter motor is cranking the engine.
    now as this is electronic ignition and there aren't any points the reason for it to be there i am not sure other than the car doesn't need a full 12 volts heading down the line
    in the pics i have supplied you can see the thingy sitting there all connected up and as with other 604's i have seen with the same conversion they have been there as well
    as i am not an ignition specialist i am sure someone can come up with a reason why it has to be there or even if it is needed
    but it's there and it's connected and i have seen others the same way so i think there must be a reason
    i can't see why you couldn't use the relay for the pump
    seems logical
    i have just wired them up via the coil
    or you could be tricky and wire the pump up through your tail lights
    i did this on a 504
    works as a bit of a daytime anti theft device
    1 x 2018 3008
    Member alan_505's Avatar
    Melbourne,Victoria,Australia
    42
    The ballast resistor is used to drop the voltage to the coil whilst the engine is running, whilst the engine is starting the ballast resistor is bridged out, the reason for this is as the motor is being turned over by the starter motor the voltage will drop, if you were using a 12v coil it would not be getting full voltage and would not develop a good spark but if you use a 9v coil and apply the full starting voltage at the coil you get a good healthy spark, and when the engine is running you get voltage is dropped across the ballast resistor so that you get 9v at the coil so that you do not burn out the 9v coil. The coil can stand the over voltage at starting because it is only for a short time but if you were to run the 9v coil at 12v for a long period of time the coil will burn out.
    Alan
    Mar 2003
    Tasmania
    1,419
    Ben, if you want to take a look at a Volvo ignition conversion, you are welcome to have a look at mine.
    Pugs Rule!
    403, now sold
    404, project
