pug help in Adelaide
  • 1 Post By schlitzaugen
Thread: pug help in Adelaide
    Jun 2018
    39
    Default pug help in Adelaide
    Hi everyone,
    On Saturday morning I'm flying into Adelaide from Melbourne to pick up a 93 205si. It has a radiator leak and I will be taking a replacement one with me but I'm in need on a bit of space to work on the car because I think the forecast is for rain. I will have the tools but I need a driveway or some space for about an hour so I can swap the rad over.
    Any help would be appreciated
    I'm not sure if this is the right place to ask so if not the admin can delete this.
    8,555
    Find the nearest mall/Bunnings/similar with underground parking.
    You might be lucky and find a power outlet as well if you need one.
    Do you intend to drive it home?
    Roland likes this.
    ACHTUNG ALLES LOOKENPEEPERS
    Jun 2018
    39
    Yes! The car is my way back to Melbourne. Covered parking somewhere is a good idea. Thanks
    8,555
    Well, it's a good plan B if all else fails but perhaps be prepared to have all tools you might need on hand and easy walking access to a part shop nearby in case something else is needed. Also a good place to leave the car overnight if things take longer than expected.
    Also, makes it obvious you have to have some light source with you.
    One word of (obvious as well) advice if you want to drive it back, make sure your headlights (and generally speaking all other lights, but especially headlights) work reliably before setting off. It's easy to overlook this given that you are focused on the cooling system.
    And check your oil.
    And bring lots of duct tape.
    Let us know what happens.
    PS. Check your wipers work too.
    Jun 2018
    39
    I think all the light on the car work except the reverse lights. It’s what I have been told but will double check once there along with oil and everything else. I’ll post a few photos of the car and let you know how it goes once I’m there
