Peugeot 407 No Low Beam???
Results 1 to 8 of 8
  • 1 Post By keithm
Thread: Peugeot 407 No Low Beam???
    Apr 2004
    Western Australia
    237
    Default Peugeot 407 No Low Beam???
    Today I changed over my headlight globes to Osram globes as suggested on another post. I have managed to do it despite having big hands The problem is I now have no low beam on the drivers side I cant see a broken wire and wonder if the computer needs to be reset??
    The fuse seems fine??
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Are you sure that you do not have a dud globe?
    Put the old globe back in and try it.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    Armidale
    2,110
    Agree with Col - there's no computer setting involved - it's got to be a physical problem. Did you get the plug on correctly? If so, and the globe is OK, then check the plug - maybe there's a bad connection.
    Alec
    145
    Check the earth connection hasn't been dislodged when you changed the globes . It is a small push on quick connect out of the way onto the light housing . Mine gave me some grief , not a great design . Hope this helps . Keith
    Armidillo likes this.
    Apr 2004
    Western Australia
    237
    OK thanks for the advice I fixed the problem faulty connections.
    1,574
    Osram bulbs, which ones, I too have a 407 with headlight improvement required.
    307 HDi wagon
    407 HDi wagon
    Apr 2004
    Western Australia
    237
    Hello Matthew,
    Osram Night Breakers sure seem to be the go .You can get from UK via Ebay at a good price.
    Oct 2014
    Brisbane/Australia
    361
    I have put new earth cables at both front lights and both rear light clusters. Unfortunately, I still blow a H1 bulb in my 407 sedan every 3 months ad it has done so since I bought the car. I just live with it. The lights are that bad, having a little less with a blown bulb is barely noticeable anyway.
