504 intermittent wipers
    Lilydale, Melbourne
    2,095
    My 1980 504 has intermittent wipers but they don't work. The previous owner told me that there is a unit under the dash that needs replacing. I'm wrecking another 1980 504 and have found a couple of black plastic gizmos under the dash, but I'm not sure which one is for the wipers. One says "MIXO" on it, another says "Cartier - Temorisateur". Is one of these the one? I can't find the answer in the wiring diagram in the Haynes manual.
    John
    John W
    1974 Peugeot 504 TI
    - now on the road
    Lilydale, Melbourne
    2,095
    Dave? Ray?
    John W
    1974 Peugeot 504 TI
    - now on the road
    Guru davemcbean's Avatar
    Apr 2001
    Camden NSW & Selwyn NZ
    2,334
    peujohn:
    Dave? Ray?
    Sorry John, I've never had a 504 with intermittent wipes. Must be a 1980 onwards thing. If so, Ray may know about them, since his wagon is an 82 or 83 model.
    Dave
    NZ Fleet
    1976 504 Ti
    1984 205 GT twin carb
    1991 205 SI 1.6GTI motor
    1994 106 Xsi
    1996 Mondeo V6
    Aus Fleet
    1955 203C
    Fellow Frogger! aquinian's Avatar
    WA
    604
    davemcbean:
    peujohn:
    Dave? Ray?
    Dave
    Yes, I had a '79 504 with these. It appeared to me to be an after-market kind of thing. The timing was set by a knob added under the dash on the right side of the wheel (a bit like some after-market air-con units). Not sure if this was the actual timer, or if it was just a switch which sent a signal to a timer unit in the dash itself, however.
    Sorry Peujohn! Looks like you're on your own. (I do think the temporiseur thingy is the indicator unit, however. You can always check by pulling it out and seeing what doesn't work any more, if anything.)
    John Lane.
    Current: 406 Coupe, 504 Sedan
    Previous: 306XSi, 205GTi, 206Gti, 505 V6, 505 Wagon, 504 Sedan, 504 Wagon, 306Gti6, 306XT, 205Si, Citroen XM, Citroen Xantia
    Fellow Frogger! sfrawley's Avatar
    Feb 2001
    Goolwa SA
    339
    I have the original handbook for a 1980 504. There is a "Screen Wiper Timer Relay" and a "Screen Wiper Relay" side-by-side on the wiring diagrams. The timer relay has 4 wires connected to 3 points (2 are joined) and the wiper relay has 6 wires connected to 5 points (2 are joined) plus an earth. They are attached to the harness that leads from the lights/wiper switch to the wiper motor. The timer relay sounds like the one you are looking for.
    Hope this helps.
    <small>[ 12 September 2003, 10:04 PM: Message edited by: sfrawley ]</small>
    Stephen
    '03 P406 HDI
    '16 Renault Master
