Peugeot 203 Engine Swap - Page 2
Page 2 of 2 First 12
Results 26 to 36 of 36
Like Tree10Likes
Thread: Peugeot 203 Engine Swap
  1. #26
    Jun 2018
    51
    Quote Originally Posted by fnqvmuch View Post
    Attachment 107478- in period, as mentioned by lozenge
    while technically not the original engine a 403 would be what is found in 203s more often than not and most engineers wouldn't know the difference anyway. FWIW i had it on the best authority your engine bay is wide enough for a ford windsor(whatever that is).
    i wouldn't expect the Daimler V8 was a flat head, by the way. Maybe a flat plane, like the lancia D50? They sound good.
    Thanks for that! Would they match the engine number though? Sorry to ask, but the cars been out of rego since 1981 and I have no idea the procedure they go through now. Would be good to try to get know as much as I can before I start even considering putting the 403 motor in.
    Probably a flat plane, was just saying in general that a flathead was my all time favourite. Hands down. Check this out
    https://www.youtube.com/watch?v=FpoUtzedVWk
    In love!
  2. #27
    8,937
    Not a flathead, a one off designed in England. 2.5 litres.
    Quote Originally Posted by James Gelido View Post
    I can imagine! Flathead V8, my favourite note of all time! Its a shame all this red tape, engineers certificates etc certainly don't make it viable for young enthusiasts.
  3. #28
    8,937
    I have a manual, could build the engine but am in Melbourne. No idea about engineers certificate.
    Engine would cost between 3 and 4 thousand dollars to those specs. Holden idea is cheapest and easiest.
    Hi Graham,
    Turns out my father has a 403 engine sitting under his house. Good news is that it turns over, bad news is that it hasn't been running in over 35 years. I will work to get it up, cleaned and prepared as I am going to go with 404 1600 sleeves a mild cam a bit of head work and a set of extractors and twin solex carbies. Least amount of work, and easily adaptable.
    Would you have any idea if I would need an engineers certificate? as it is technically not the original engine. Also, would anyone here know where I could get a 403 workshop manual or someone I could take the engine to for a rebuild?
    So eager to get the beast going!
    James
  4. #29
    Avisford NSW
    531
    I have 50 years experience with Peugeot engies and have built several of these special enginesover the years I am based in Mudgee and come to Sydney very often will be at AFCD on Sunday 0458207064 after midday tomorrow will get me
    Also have a w/shop manual $10
  5. #30
    8,937
    You can use a 403 block with the 404 liners (people will tell you it has to be 203) but you need to make up spacer rings to extend bottom sealing surface of liner downwards. You need to use early 404 pistons, the later ones will give too much compression. Otherwise over to Ian.
  6. #31
    Mar 2005
    greystanes sydney
    5
    Hi James
    If you a free on Sunday the 15 7 18
    come out to all french day at silver water park
    there may be a twin carb 203 there on the day
    your are bound to get some good info there
    its the 70th Birthday of the 203 so there should be a few there
    A standard up grade is to put in a 403 engine just short of a 1500
    https://www.google.com.au/maps/searc.../data=!3m1!4b1
    My car is a Grey 403
    Come up and have a chat I will introduce you to a few the right people
    We loved to see where your up to on your car
    pug 58 403
  7. #32
    Jun 2018
    51
    Quote Originally Posted by ianrobbo View Post
    Hi Ian,
    Thats the best news I've heard in a while. Was going backwards with my 203 for a while there. Would love to have a chat and see if we can get the old girl going again. I'll give you a ring tomorrow if thats okay I've attached photos of the 403 ....
    Peugeot 203 Engine Swap-403-engine-2.jpg Peugeot 203 Engine Swap-403-engine.jpg
  8. #33
    Jun 2018
    51
    Quote Originally Posted by pug 58 403 View Post
    Hi James
    pug 58 403
    Hi,
    Awesome, Perfect timing! Would love that. What time was the meet?
    Thanks again and hope to see you soon!
  9. #34
    Jun 2018
    51
    Thanks so much Graham for all the info. You have really helped boost motivation again to get the ball rolling. We just done the wheels with satin red today and waiting for the white Portowalls/white walls to arrive. Shes going to be a site!
    James
  10. #35
    1000+ Posts driven's Avatar
    Apr 2005
    1,294
    The V8 had a Hemi head
    Bore 3" Stroke 2.75". Only 2.5L as any more it would have been more powerful than the 3.8L Jag at the time
    I had one beautifully smooth high revving 6000rpm V8 for the day
  11. #36
    8,937
    Daimler designed and built the engine before Jaguar took over. They had a bigger one, 4.5 litres or so, but Jaguar only used the small one in the Daimler version of the Mk2 Jaguar because as you say, it would have been a better engine than the Jaguar 6.
