Speed Limiter
Results 1 to 13 of 13
Thread: Speed Limiter
    Fellow Frogger! koppers's Avatar
    Jul 2003
    134
    Default Speed Limiter
    Any information on speed limiters in pugs at all? Do they exist? I have this 'friend', and he said that it would go any faster than 180, despite the fact he had more revs to play with.
    Silly boy he is...
    Any thoughts peoples?
    Adm.
    12,266
    Quote Originally Posted by koppers
    Silly boy he is...
    Adm.
    not sure about the pugs but it may be worth finding out for sure
    i know falcons are speed limited to 180km/h hence i never believe people when they say they did some great speed from one unless they have played with it to bypass the limiter
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    XTC
    XTC is offline
    Mar 2003
    Location Location Location
    8,566
    Any information on speed limiters in pugs at all? Do they exist? I have this 'friend', and he said that it would go any faster than 180, despite the fact he had more revs to play with. Silly boy he is... Any thoughts peoples?
    Adm.
    Which model ? 206GTi will do 215kph (so I'm told ). Van from 206gti.net will confirm.
    - XTC206 -
    Now this is a .sig
    1000+ Posts n b j's Avatar
    Jun 2003
    1,239
    I don't know about speed limiters but I have done just over 190km/h in my car
    about 191 or 192km/h, I was doing about 6,500rpm or just less then that in 5th gear and I was on a very slight down hill.
    And no, it wasn't on a public road
    "Do my eyes deceive me, or is Senna's Lotus sounding rough ?" - Murray Walker
    206XR 1.6ltr - SOLD
    BMW E36 325i Coupe
    73 Porsche 911RS
    1000+ Posts N5GTi6's Avatar
    1,106
    From experience GTi6's are speed limited to about 225km/h....
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    My son spends his time fiddling with the internals of engine management systems & the like & the only car I have ever heard him make comment on having a speed limiter is his GT-R.
    It's apparently law for them to have them in Japan on certain ultra high performance cars.
    A Pug, Mi16 I've no doubt you're referring to, will have a rev limiter of course which up to a point does the same job and on them it's set around 7200 rpm.
    In either case, rev or speed limiter, I know it's possible to increase the limitations but not something you'd want to do without first finding out whether the engine will stand the increase you intend taking it to.
    Alan S
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    European cars tend to only have electronic speed limiters set to 155mph (about 250km/h). So if the car isn't capable of that sort of speed, you won't have anything. To limit a car below that speed woule make it dangerous on the high speed Auto Bahns etc.
    Nick
    1983 Peugeot 505 GR
    1000+ Posts Luca's Avatar
    Mar 2003
    1,335
    I dunno about the new new pugs but the rest of them never had speed limiters... as previously mentioned they did come with rev limiters (Mi16 had one) along with models such as the 605 (a.k.a the tasmanian devil) would have had rev limiters.
    Mar 2003
    114
    I think the 180 kmh limiter in Japan is fitted to ALL cars?
    EMC
    EMC is offline
    Member EMC's Avatar
    Mar 2003
    Indooroopilly, Brisbane, QLD
    64
    my car has a mechanical speed limiter... its called 90HP engine with 4 speed gearbox ^_^
    1979 Peugeot 504 GL
    1000+ Posts dino's Avatar
    Nov 2002
    4,606
    "i know falcons are speed limited to 180km/h hence i never believe people when they say they did some great speed from one"........
    HMMMM...thats interesting......do u know which models does it apply 2?...because i m sure i ve hit close to 192kmh in an EL.....was a fresh rental with like less than 1000kays on the clock...i was one of the first to drive it.....is it possible for it to have been rev limited to 180 but display the often incorrect speedo figure...ie i was doing 180 but speedo was showing 190+???
    interesting nevertheless......
    cheers
    dino
    Jul 2003
    134
    My car is a '96 306 XR.... I still had a little under 1500rpm to play with in top gear, which was quite long I found.. Even at that speed (180 km/h) down a slight decline, it would not pick up even one km/h more...
    Adam
    Fellow Frogger! MR604's Avatar
    May 2002
    Bathurst
    946
    I had a part time speed-governor on the bike.
    When I had the wife on the back and she thought I was going too fast she'd punch me in the kidneys
    A computer lets you make more mistakes faster than any other invention in human history, with the possible exception of handguns and tequila. - Mitch Radcliffe
