please help peugeot 504
Results 1 to 15 of 15
  • 1 Post By dino
Thread: please help peugeot 504
    May 2018
    Uk
    7
    Icon1 please help peugeot 504
    I have Peugeot 504 GR 1983
    what would be the best spark plugs and advice on where to buy the air filter and the best make ? and other filters
    Thanking you all
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    620
    I go for NGK or Denso Iridium.
    They last for years and spare the cylinder head thread from wearing out (by reducing the number of spark plug changes)
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Fellow Frogger! John505's Avatar
    Apr 2005
    Morwell, Victoria, Australia.
    180
    Make sure you use copper eze on the threads of the platinum or iridium spark plugs if you expect to be able to easily remove them after 60,000km or so. Otherwise, stick with NGK or BOSCH plugs.
    John505
    Fellow Frogger! 505604's Avatar
    Junee, NSW
    673
    As to where to purchase your parts, Iíve been buying from Ken at Parts of France. *0400 566 119‬
    http://www.partsoffrance.com.au
    [email protected]
    Andrew
    Current cars: Peugeot 307 HDi Touring; Peugeot 306 Cabriolet; Peugeot 406 HDi, Peugeot 505 Familiale
    Previous cars: 1965 Peugeot 404; 1972 Renault 16TS; 1970 Peugeo 504 1800; 1978 Peugeot 504 GL; 1976 Peugeot 504 LTI; 1984 Peugeot 505 Familiale; 1982 Peugeot 604 (converted to TD) 1999 Peugeot 306 Cabriolet
    May 2018
    Uk
    7
    Default Hi
    Quote Originally Posted by Doush_504 View Post
    Hi Doush,
    Thanks for such a quick reply! I had a look online but I would appreciate it if you could let me know which model number it is or the link I could click on as I looked it up but it was hard to find.
    May 2018
    Uk
    7
    Hi John ,
    Thanks for the advice would u be able to send a link or model number .cheers
    Armidale
    2,229
    Hi Al504
    Remember we are in Australia, and while many of us buy stuff from the UK and Europe, there seem to be many auto spares places over there that won't mail stuff to Australia, so we only have experience with a subset of the options available to you.
    That said, I realise that 504 parts are not going to be sitting on the shelves of every auto spares outlet, so Aussie 504 owners may be able to help. GSF car parts carries a small amount of 504 stuff, but seems to be mainly for late model diesels. Micks Garage claim to carry service items for all 504s, so might be worth a look!
    Alec
    Armidale
    2,229
    Quote Originally Posted by Al504 View Post
    Hi John ,
    I think you need to give us a bit more information - especially which engine you have. You'll find that the spares places do not usually care about trim level codes like GR or GL, but want to know your engine type. Once you know that, you'll be able to find what you need on sites like Mick's Garage.
Name:	Micks Garage 504.jpg
    May 2018
    Uk
    7
    Hi Alec ,
    The website was very helpful I had hard time finding parts before what does GR or GL abbreviation mean anyway?
    May 2018
    Uk
    7
    Hi
    any advice on the best headlights bulbs to buy ! cheers
    Sep 2003
    North Parramatta
    3,981
    Hi Alec ,
    GR and GL refer to the trim level, generally, but can sometimes reveal the mechanical setup, ie. live axle, independent rear, etc.
    Unfortunately they are sometimes only appropriate for a particular market.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! Pug72's Avatar
    Feb 2013
    274
    In my 1972 504 GL 2 litre petrol I run NGK spark plugs either BP5ES or BP6ES. The BP6ES plug is whats recommended by the manufacturer, however the BP5ES runs a little hotter and may help to burn off carbon deposits in an older engine. I run 98 octane unleaded. Timing needs to be spot on to avoid "pinging" and piston damage.
    As for headlight bulbs, what type of headlights do you have? Are they standard sealed beam, or Trapezoidal?
    As for an air filter - depends on the type of air filter set up on your 504. Most early 504's ran an oil bath
    Pictures would help
    Cairo, Egypt
    620
    Hello
    The NGK part number is: BPR 6 EIX
    Denso: IW20
    Hi Doush,
    Chadi
    All since new
    1000+ Posts dino's Avatar
    Nov 2002
    4,513
    If its a carburated car... i would not bother with iridiums... stick to stock plugs... iridiums are great on modern engines with sophisticated engine managment... but on an old 504 imo they are a waste of money...
    Dino
    cjl likes this.
    May 2018
    Uk
    7
    These are the headlights what is the best headlight bulbs to go for and the model of them. Thanks for all your replies.
