carbon clean - Page 2
Page 2 of 2 First 12
Results 26 to 44 of 44
Like Tree13Likes
Thread: carbon clean
  1. #26
    Armidale
    2,184
    Quote Originally Posted by pgti6 View Post
    This has been an interesting and timely thread ...
    Assuming that PSA has learnt nothing other than emissions control, the 1.2 would suffer the same poor engineering of the EP6?
    I would keep asking the question. I have heard that the 1.2 is much better engineered than the 1.6!
  2. #27
    Fellow Frogger! Mi16 Man's Avatar
    Canberra, ACT
    709
    This works a treat too...
    SLC206 likes this.
    "Take a Lion through a corner - FAST"
    Current Fleet;
    2010 308 XSE HDi SW [Vapour Grey]
    2010 VW GOLF GTI [Carbon Steel Grey]
    In the Family;
    2012 508 Allure HDi [Thorium Grey]
    2008 207 HDi XT [Bianca White]
    Past "Frogs"
    2008 308 XSE HDi SW / 2006 307 XSE HDi Touring / 2001 306 XSi / 2005 206 GTi180 / 2005 407 HDi / 2003 206 XT / 1993 SII 405 Mi16 / 1990 205 GTi / 2x 1985 505 GTi S1 / 1976 504 / 1982 20 TS / 1997 306 XR / 1992 205 Si
  3. #28
    6,141
    NO! T'was a poor Stuey joke. I realised the joke wouldn't work when I thought...hmmm, that sounds actually quite feasible...
    Is that so?
    It should work, not sure how it would go with being burnt through the engine..
    2003 PEUGEOT 206 GTi
  4. #29
    8,633
    Is that so?
    Burning would be fine, but I wonder how soon after that you have to replace the head given that oven cleaner is actually sodium hydroxide, which as we all know from school chemistry is going to attack Aluminium like it's nobody's business.
    I am sure it works a treat with dissolving the crud, though.
    ACHTUNG ALLES LOOKENPEEPERS
  5. #30
    Dec 2011
    Australia
    4
    I'm not sure I'd use various additives that claim to clean the engine ESPECIALLY ones that you spray into the intake with the engine idling. That shit is gonna end up all over the sensors in the exhaust and the catalytic converters, who knows what damage it will cause there?
    I'm not into half measures.
    The safest course of action is to pop off the intake and walnut blast it.
    Here's a guy doing it on his mini (same EP6 engine but the engine layout is slightly different)
    https://www.youtube.com/watch?v=KFvXbTIiAVY
  6. #31
    8,316
    Useful info about the problem but not very helpful to PSA owners. The access in the Mini is better (less windscreen overhang) and the air cleaner and air ducting is different.
    Walnut blasting is great for the few places that have gear that fits.
    Dealers use a different tool.
    Hand scraping always works and a small scraper is cheap. Some compressed air helps to blow crap out, but even aerosol air will do.
    Don't under-estimate the time to strip and replace the manifold. There are electrovalves, connections, etc buried away down in there and it helps to know where they and their fixings are, as vision is exceptionally poor. It isn't essential to remove the injector rail, but I reckon it helps access. The valves must be closed as the video mentions.
  7. #32
    Dec 2011
    Australia
    4
    Same engine but with slight difference - definitely useful. If you are skilled enough to attempt a job like this you can use that video as a reference and figure out the rest as you go.
    Walnut blasting isn't some sort of amazing specialised thing, all you need is an air compressor, media and a blasting "gun" with suction feed and you're away. The media in this case is fine walnut shells which incidentally is used for cleaning firearms so your local firearm supply shop should be able to help you if you find that it is not readily available.
    Any solvent will do in a pinch. You could probably get away by pouring petrol in there, wait, scrub with wire brush and a pick then compressed air / vacuum out the leftover pieces. But if you're going to go to all the trouble to do this (remove intake etc), I figure it is better to spend the extra $100-$150 and buy the media blaster gun + media and do it properly.
    A great portion of modern turbocharged vehicles are now DI; whatever parts I buy for this will no doubt come in handy in the future.
    Removing the intake is the most complex part of this job.
    I'm just waiting on my media to arrive, once I have this I'll post a complete how-to with before-after pictures.
  8. #33
    Oct 2003
    611
    Each to their own but you will get adequate cleaning using Carby clean, a toothbrush, a teaspoon and compressed air. Also two steps forward, one step back if you don't fit a catch can to alleviate the issue.
  9. #34
    8,316
    I tried that once. It doesn't do it, not when the crud builds up. A catch canl help, but won't stop it. I suggest that C2 low ash oil, as now recommended, will be more useful.
  10. #35
    Sep 2013
    113
    Direct injection is here to stay.
    However, some manufacturers are playing with dual injection systems. So running both port and direct injection. There are alot of benefits to this as you can play with the fuel maps more especially engines with VVT & VVL, also removes/reduces the issues with the valve and port clogging as the fuel is washing over the port and valves.
    id HIGHLY recommend following this process
    - Media Blast on any EP6 after 80,000 km.
    - Delete the factory PCV system and install a catch can.
    - Only use Low Ash C2 engine oils.
    - Only use 98RON Fuel.
    - Service every 5,000 km.
    - Carry out a seafoam/ upper engine clean every 5,000km (carry this out BEFORE you do the oil change.)
    For those wanting some extra power and clean - look into a water/meth kit
    PM Me for all New Genuine Spare Parts & Accessories.
    Current:
    2007 Peugeot 207 GTi
    ...Let the mods begin...
    Previous:
    2000 Peugeot 206 GTi - SOLD
    1995 Peugeot 306 S16 - SOLD
  11. #36
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    618
    Actually these oils are causing a ton of problems to these engine due to being too volatile thus generating lots of vapor (specially in hot climates).
    I have been using BMW LL01 oils (= PSA B71 2296) for years now with zero problems concerning carbon buildup or flat spots or rough idle. Also the keep going for 10k Kms without the need to top up as the dreaded C2 & C3 oils do.
    BMW forbids the use of LL04 (= PSA B71 2297 or B71 2290) outside of Europe for these engine.
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
  12. #37
    Jun 2018
    Wheelers Hill
    6
    Many thanks for the many and comprehensive replies. Talk about can of worms. Now miss my 505 GTI and even my 504s or my 404 !
    Regan quote $1800 as well. Now running 98 to see if it helps and might try nylon or similar alltho thatís more injector oriented rather than inlet valve.
  13. #38
    Jun 2018
    Wheelers Hill
    6
    Oops meant Nulon not nylon
  14. #39
    8,316
    That's a lot of money for the job, and reflects expensive dealer charging. Talk to an independent Pug place. 98 won't help, and the Nulon/Seafoam/Subaru cleaner approach only works when the valves are reasonably clean. You might get a short distance out of it.
  15. #40
    Jun 2018
    Wheelers Hill
    6
    Given the car has been regularly serviced, the need for a carbon clean at 80,000 does not seem to reflect well on Peugeot. This is a one owner car bought new from a dealer.
    If itís reasonable to assume that the carbon buildup is caused by the failure of the valve seals, then again not sure if Peugeot have in fact dealt with the longstanding reliability issues that some Peugeot workshops insist have been addressed.
  16. #41
    Sep 2003
    North Parramatta
    3,975
    Quote Originally Posted by liefrog View Post
    If it’s reasonable to assume that the carbon buildup is caused by the failure of the valve seals, then again not sure if Peugeot have in fact dealt with the longstanding reliability issues that some Peugeot workshops insist have been addressed.
    I don't think it's reasonable to assume that carbon build-up is caused by a failure of the valve seals, as it's well-documented as to why direct injection petrol engines (not just Peugeot ones) have carbon build-up on the valves.
    Having said that, it you are only worried about "the odd times it has a flat spot" then I wouldn't worry at all. It's certainly not worthwhile giving Regan or Bayside the exorbitant amount of money they are quoting you.
    Mi16 Man likes this.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
  17. #42
    wid
    wid is offline
    68
    So does the carbon build up happen to every 1.6 turbo car or is it a result of driving style or patterns? ie lots of short trips, and feeble driving. Are we talking inlet or exhaust valves?
    I still hanker for a 508 but hearing all this why would you?
    I have heard high pressure fuel pumps are an issue too. ie they fail. Any comments?
  18. #43
    8,316
    Valve cleaning is needed at some point in all direct injected petrol engines, so in PSA terms, that is the 1.6 THP and the 1.2 EB2 engines, both modern Euro 5+ complying designs. All makers have adopted this approach in their newer engines; they seek higher output for lower fuel consumption and lower pollution. The injectors aren't simple sprayers any more. Like the common rail diesels the pattern varies during the cycle and is driven by the engine computer.
    The problem comes from crankcase oil vapour that didn't get condensed by the separator, and turbo bearing bypass, so has little to do with driving style - it is better related to engine hours or distance covered.
    Oil vapour comes in contact with the inlet port and inlet valve in the port - both very hot. It burns, and the adhesive ash residue builds up. The idea behind the dissolving sprays is to try to limit build up. They help.
    High pressure fuel pumps were a common failure in early 1.6 engines, years ago. The design was changed and the problem was greatly reduced. The current 1.6 engines EP6CDTX have a different pump design altogether.
  19. #44
    Jun 2018
    Wheelers Hill
    6
    Thanks Simon and yes I had thought just put up with the occasional flat spot, however the self professed expert and recognised Peugeot specialist at Bayside advised me that if not fixed basically the engine would end up not working. He did express this in technical terms but I canít recall his technical prognosis.
