207 touring HDi
Results 1 to 22 of 22
Thread: 207 touring HDi
    Jun 2018
    Orelia, WA
    34
    Default 207 touring HDi
    My son just got a 2008 207 touring with the td motor.
    He is not a car guy at all, so I am here instead.
    We paid below the odds for it and it looks nice but has a few battle scars when you look close. It is his first car, so that is not a problem.
    I can't believe how nice this thing is, both to drive and to be in.
    It had a couple of issues, but thanks to this site and the pommy one as well, I have tracked them down mostly.
    The intercooler pipe was loose, but we have that sorted, however I think that has caused the dpf to fault.
    I have had it out for a couple of long drives to see if it will regen, but it still throws the "depollution system fault".
    Might have to take it for a forced regen.
    I will have a few questions along the way, but much of them have already been answered by this site.
    I am seriously looking at finding one of these for myself.
    Assuming we can sort this, which I am confident we can.
    So anyway,
    Hi from Dave, new (proxy) Pug owner.
    8,424
    Welcome to AF.
    The 1.6L diesel? The most important maintenance for this engine is the oil change! Don't neglect it, and always use a C2 very low ash oil, such as Total, and a long life awaits. Otherwise you risk ash deposits in the engine and a ruined turbocharger. There is no shortage of advice elsewhere in the forum.
    For the depollution business I suggest you find someone, AF or mechanic, with the factory software, and get a full diagnosis. There are too many possibilities. If indeed the particle filter needs a regen it can be done (spectacularly) by computer, outside and not on grass!
    Jun 2018
    Orelia, WA
    34
    Thanks for the advice.
    We have just purchased it, and although we were told it was recently serviced, we will get it done this week.
    I wanted to make sure of the oil type first.
    I have a bluetooth obd2 dongle and generic software, and some knowledge of how to use it.
    Indeed, it was partly that which revealed the loose intercooler pipe - From it I figured out what to look for.
    I have addressed each of the faults in turn and have only one left, which I think is pointing to the dpf.
    Anyhow, I appreciate your advice and will keep trolling around here here for answers.
    Seems like a good resource this place.
    Thanks to all who have posted stuff that has and will help me out.
    8,424
    PSA recommends Total Quartz Ineo ECS 0w-30, which isn't easily found at retail outlets in NSW, thanks to agreements with dealers, though it sometimes shows up
    If you want a bulk package (eg 3x5L in a carton) of Total try an interstate distributer, eg Onshore in Qld.
    Penrite also has C2 grade, which can be found in most auto spares places. Magnatec C2 Professional is available in bulk if you know a mechanic well enough.
    The filter only regenerates when on a sustained fast run, every few hundred km. The easy way is a motorway drive every so often. That way the heat and aparks out the back endanger nobody. Unfortunately there is no idiot light or message to say when it is happening.
    Jun 2018
    Orelia, WA
    34
    Hmmm - I am in Western Australia, and I am partial to Penrite with a good autoshop nearby.
    I will check for the C2 grade.
    Not noticed the sparks, but we also had been babyong due to the turbo pressure leak. I will take her for a good solid freeway run tomorrow I think.
    Thanks.
    1000+ Posts N5GTi6's Avatar
    1,088
    Just be aware too that if you can't find C2 oil, C3 oil has the same rating as far as your DPF goes. The only different between C2 and C3 oil is a very small percentage potential in fuel savings.
    We've always used a 5W-30 grade oil - I believe that a 0W-30 grade oil will be too light for that engine.
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    8,424
    Penrite C2 is everywhere, in 2 flavours. The cars came from the factory with 0W-30 in them, with a recommendation to use 5W-30 at servicing. Lately I''ve been told by dealers that the regular service grade has been revised downward. It is also recommended to use the same oil type and grade in the 1.6 turbo petrol engines.
    Sep 2003
    North Parramatta
    3,981
    Quote Originally Posted by Skellibert View Post
    The benefit of you being in WA is access to Golden West Lubricants, which sells Total INEO ECS 5W30 very cheaply.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jun 2018
    Orelia, WA
    34
    Quote Originally Posted by SLC206 View Post
    I have used penrite for years my old cruiser and pretty much everything else. Is the "Total Ineo" that much better?
    Not dissing you at all - genuine question. I will look them up.
    And I notice you have a bit of a GTi problem there....
    I gotta come clean here folks - I am a bit of a FIAT guy, but always had respect for the froggy cars.
    And in general I am a car tragic - if it is not mainstream I sorta want it.
    Several Fiat's, right now a US Chysler neon (not sure what is wrong with it really, but not sure I want to spend any money on it.) Had a Niva..... loved it.
    Now discovering the Joys of the Pug.
    1,088
    lol - I've owned 5 X 124 coupes......last one was an AC with 1756, twin dcoe's, early diff, late gearbox, late seats, extractors, high comp pistons, big Waggot cams, 6.5in rims, Koni's, lowered springs........I love my Fiats as well !
    Justin
    '07 C3 Exclusive
    Sep 2003
    North Parramatta
    3,981
    I'd be happy to use Penrite Enviro+ oil in 5W30 - but from what I've read on here, the correct Total oil is $15-$20 cheaper (for 5L) than the Penrite oil if you buy it from Goldenwest. I think they are in Maddington.
    Last I read you could buy 3x5L for $123.00, for example, which seems like a much better deal than we get in the eastern states, where dealers can attempt to charge you $120 or more for one 5L bottle.
    Simon
    Jun 2018
    Orelia, WA
    34
    Last I read you could buy 3x5L for $123.00, for example, which seems like a much better deal than we get in the eastern states, where dealers can attempt to charge you $120 or more.
    Ok then - I will definitely look them up. Maddington is not too far, and I am cheap enough to want to save some shekels if we can.
    This has been excellent thanks guys.
    8,424
    Someone here once reported getting Total from Golden West into NSW by courier still at a very competitive price. A carton of 3 bottles would make the trip worthwhile.
    Jun 2018
    Orelia, WA
    34
    Update: I took the little pug for a good long run down the freeway - about an hour at 100kph in fourth - not stressing the little thing out but buzzing along nicely. Stopped at a servo for five minutes, had a little look around and everything seemed fine. Took off and almost immediately had the "depollution system faulty" message come up and revs restricted to 3000rpm.
    Pulled over, stopped, key off and back on, restarted and although the fault was still showing the car was perfect all the way home.
    Took the car out again today, this time a traffic workout. No fault lights at all, no engine light. I haven't hooked up to check the fault codes yet.
    But today it has been faultless. Maybe the run the other day was enough to burn out the DPF, and hopefully that is the last we will see of that.
    Time will tell, and I will be keeping a check on it.
    Jun 2018
    Orelia, WA
    34
    Another update: car is still running like a top, with no faults showing. The yard we bought it from must have had the faults show and hence the low price we paid, but I was able to find a wrongly placed bolt, replace a headlight bulb, and "long run" burn the dpf clean and we now have a beautifully running, low km 207 td that cost us below the odds.
    And the ability to search, discover, and solve the faults and issues was in part due to this site.
    Needless to say, I am happy.
    Now I just have to figure out a way to get my son yo sell it to me....
    Jun 2018
    Orelia, WA
    34
    Long time no chat - very busy with all sorts.
    Is there anyone south of Perth with the program to do a forced regen on the little 207?
    I am in the Kwinana area.
    The 207 has gotten progressively worse with the dpf fault until now it is basically undrivable.
    Does anyone know of the FAP program can do a forced regen?
    Or is there an android app that will do it through the obd2 dongle?
    8,424
    I've done the regen using Diagbox, the factory software. Copies of doubtful origin abound, and there are articles here about installing it.
    The process involves revving with altered combustion, is very hot and nasty, and the car should be outside, on paving, not over combustible vegetation.
    dmccurtayne swears by Delphi OBD readers, and he may know if one of the clones can do it more easily for you.
    Does the car regularly do uninterrupted steady speed trips to allow the car to regen itself?
    There are Android OBD2 readers, but many cannot provide more than error code reads and resets. A current code read would be useful.
    Jul 2013
    Newcastle/ central coast
    1,568
    Yep copy that ds150e will do a regen on everything upto 308t9 and it does the quick old way not the 20 minute saga the diagbox does since 2018
    Garage C5 X7 3008 XTE
    Fix it right the first time
    Jun 2018
    Orelia, WA
    34
    Thanks gents.
    I have a cheap clone OBD2 which will not fully talk to the Pug (or my little Ford for that matter). It was fine for my old Neon.
    So I want a decent OBD2 reader - Is the Jaycar one good? Or is there a good source for a decent one?
    And because I am lazy - is there a link for the ds150e on here somewhere that you guys know? If you have to search then I may just as well do that...…
    Is the ds150e available on android or is it MS only?
    Jun 2018
    Orelia, WA
    34
    OK guys, I went and did a little investigating, and found out the answers - Windows only, I will have to see what dongle I can find - my son's laptop does bluetooth, so I shoudl be able to get a BT dongle that I can use with my phone also.
    So I have downloaded a copy, and I will set it up once I get the Dongle I need.
    Thanks for the help gents.
    8,424
    It isn't BT itself that's hard. It's making sure your purchased hardware (plug, or cable) can translate the OBD2 pin signals ino a serial format recognised by the computer's hardware (such as a USB conversion cable does). The vehicle bus protocol is nothing like a computer's internal bus.
    Jun 2018
    Orelia, WA
    34
    I have ordered an obd2 to USB cable. It says it works with pugs so.......
    And I have downloaded the suggested software.
    My bt obd2 dongle doesn't talk to everything, which is why I need something else.
    Now I just have to figure out which of my kids' laptops is available for the job. Mine has had it.......
