Map sensor Peugeot 207 gti 2007 model
Results 1 to 16 of 16
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default Map sensor Peugeot 207 gti 2007 model
    Hi everyone,
    I would like to know how would you know if your map sensor not working??
    I unplugged the cable thatís connected to the map sensor and the engine still running??? Is this normal.
    And someone told me if the engine stops thatís mean itís still working???
    Regards
    AAA
    Sent from my iPhone using aussiefrogsMap sensor Peugeot 207 gti 2007 model-img_1528109133.482815.jpg
    Oct 2003
    613
    Quote Originally Posted by AAA View Post
    By connecting a scan tool and running a fault code check! You can also monitor the sensor values as the car is being driven.
    Disconnecting parts of electronic components while engines are running is a sure fire way to damage a component, log an unneccesary fault code or trigger limp mode. This is not the 80's when a MAP sensor was the only load source the ECU used. Now multiple sensors are used so the engine will still run. And if it's like BMW's other turbo engines, it will have more than one MAP anyway.
    8,429
    You can pull the sensor out, and the engine will still turn over. You have told the computer there is no boost.
    Sep 2013
    113
    Thats not the MAP sensor. Thats the IAT (intake air temp)
    The MAP is located on the intake manifold and you need to remove the airbox to see it
    Sent from my SM-G950F using aussiefrogs mobile app
    PM Me for all New Genuine Spare Parts & Accessories.
    Current:
    2007 Peugeot 207 GTi
    ...Let the mods begin...
    Previous:
    2000 Peugeot 206 GTi - SOLD
    1995 Peugeot 306 S16 - SOLD
    8,429
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Ok I get it now. The map sensor is behind the air filter box
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Having faulty map sensor will it cause the engine to have rough idle ??
    Sep 2013
    113
    Possible. But i would have it scanned first instead of just replacing parts.
    Theres a few reasons why idle can be affected
    Current:
    Previous:
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    But itís got no engine lights and the last time I scanned it it came up this in the pic Map sensor Peugeot 207 gti 2007 model-img_1528257700.602977.jpg
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    I have also replace o2 sensor both of them top and bottom.
    Dec 2002
    2,513
    How old are your spark plugs?
    Scotty
    Melbourne - Dandenong Ranges
    1999 Peugeot 406 Coupť - 'Chloe' - 5 speed manual
    2014 Peugeot RCZ - 'Remy'
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    I change it last 7 months ago
    8,429
    Don't spend money blindly.
    The scanning tool needed is Diagbox, as used by dealers. Plenty of people here have one. It will tell you details of the fault, and which cylinder is misfiring. Do you have a code number? All readers can give this much. Misfiring codes are in the 1300s.
    Once you know which cylinder it is, swap both the plugs and the coils to two other cylinders. That is only a ten minute job. If a coil or plug is the trouble the misfire code will shift to a different cylinder. If not, then the inlet valves and breathing are suspect.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    I just clean the map sensor and big change idle back to normal but still allitle bit rough once in a while. Maybe I might have to change the map sensor since it never been change. Map sensor Peugeot 207 gti 2007 model-img_1528278781.478826.jpgMap sensor Peugeot 207 gti 2007 model-img_1528278809.812711.jpg
    8,429
    And perhaps you don't. They last a long time. You check sensors electrically, eg with an oscilloscope or voltmeter. Get the diagnostic codes.
    Also consider that one of the coil rubbers could be dirty or arcing.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi everyone ,
    Just an update on my car,
    At the moment everything is back to normal. My fuel ratio is reading back to normal before it was losing fuel and reading wasnít correct, idle is back to normal no more rough idle. Performance of the car feels like itís got more power and speed since I cleaned the map sensor. But Iím buying a new one just in case the old one plays up again. Thank you everyone for ur help.
