Peugeot 403 update
Results 1 to 12 of 12
    598
    Default Peugeot 403 update
    a friend has bought a 403 and want to update the engine and gearbox to a later engine with a 4 speed floor change box.
    Can someone suggest a suitable donor combination that doesnt require too much modification.
    Not looking at turbo or v6 !
    1000+ Posts Mike Tippett's Avatar
    Jan 2002
    Vancouver Island, Canada
    1,672
    Nardi floor shifter for the C-2 or C-3 box is a good mod. They're rare though.
    Re-engining it with a Toyota or something else would be a shame. It should be possible to get 80 HP from a modified 403 engine, I would have thought, and that would be enough.
    1966 Peugeot 404 Coupé Injection post-restoration reassembly underway!
    Register your 404: https://recensement.leclub404.com/submit.php
    Avisford NSW
    533
    404 piston and sleeves and a mild cam is a good start to the engine
    18,038
    Quote Originally Posted by petermelb View Post
    At one stage (many moons ago) I toyed with the idea of Datsun 1600 or Datsun 180B SSS engine gearbox combination.
    However the perennial torque tube adaption issues stopped anything actually happening.
    These day these donor vehicles are almost as rare as the 403 and in demand for restorers.
    with apologies to Judy Grahn
    Mar 2005
    316
    I'd look at a Volvo B23 4cyl if you're after something cheap, were available with carbs so no emissions hassles, are readily available and there are kits to fit a single rail 4 speed if you don't want to use the 4 speed Volvo box. There's also a 4 speed volvo box with electronic overdrive that is readily available
    Gardenvale
    82
    The torque tube adaption issue is the ultimate stopper when considering anything other than Peugeot parts. My suggestion would be to spend a few hundred dollars on getting the original shift working as it should - replace bearings in gear box top cover and sorting the linkage issues. A properly adjusted original shifter works brilliantly - a flick through movement to go from 1st to 2nd , similar for 2 to 3rd , and same for top back to 3rd - and 3rd back to 2nd. The other movements are a little more complex than the flick through motion but not overly so. Finally , tune/modify the engine to give a little more power .
    Aug 2012
    korumburra,vic,australia
    148
    How about a 504 2ltr, stood up and a ba10 /5 gearbox and kit instructions to fir ??
    cheers bob.
    Mar 2003
    338
    Quote Originally Posted by bob.nelson2 View Post
    cheers bob.
    I can supply a kit to fit a 2 litre 504 engine.
    Don
    Citroen DS21 Pallas 1970 Renault 16TS 1976 Renault 5TS 1981
    Fellow Frogger! fnqvmuch's Avatar
    port douglas
    860
    Quote Originally Posted by tresbon2 View Post
    Don
    So can Bob ...
    grandC4picasso RHB, [email protected] , EGS6Sp, B58, MY 2012-2013 (?)
    Mar 2015
    Tooradin Victoria
    226
    Actually Bob's has now been completed beautifully, tested and ready to go and is for sale for a sensible, affordable, negotiable price. Why not enquire?
    Jun 2018
    51
    Hi Peter,
    I am currently looking for a 403 engine to put in my 203. Would your friend be looking to offload his 403 engine by ant chance? (currently based in Sydney)
    Mar 2015
    Tooradin Victoria
    226
    Why aren't you asking Bo Nelson?
