HELP! Brake Lights Not Working!
    nJm
    nJm is offline
    Guru nJm's Avatar
    Jan 2002
    Melbourne, Australia
    2,930
    My rear brake lights only work at the moment if you give the pedal a good brisk tap. By normally easing the pedal down the lights won't come on. I have no idea how long it has been doing this, as it wasn't until mum pointed it out tonight. No wonder I've had people going close to my arse!
    What can I do? On another note, the rear brakes seem to make sqeltching noises and the brake booster is covered in brake fluid, despite it having a new master cylinder.
    Nick
    1983 Peugeot 505 GR
    9,223
    The stoplight switch on your model, as far as I know, is one of those that functions as the pedal is depressed. It's the loss of the pedal up against the switch that makes it work, not pedal pressure as on earlier systems.
    If you look under the dash you'll see it up against the top of the pedal arm... take it off and give it a bit of a cleanup for a start...
    12,266
    renault 16's as far as i know are the same switch
    fluid everywhere ??????
    look and fix ASAP
    one it sounds dangerous
    two if you get brake fluid anywhere on paint it will eat it and you can't re-paint it
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    1000+ Posts silverexec's Avatar
    Melbourne, Victoria
    1,003
    Yeah, check out the brake light switch above your pedal before you do anything else. Sounds like it's dirty or something.
    Where is the brake fluid on the booster, underneath the master cylinder or around the top aswell? I'm just guessing that maybe some fluid could have come out from the top of the master cylinder somehow, if the fluid is everywhere. Maybe?
    Richard
    - Richard
    Now: 405 SRI D70 '93
    - 2.0L manual
    Earlier: 505 GTi Executive '85
    - hence "Silver Exec"...
    25 GTX '86
    - manual conversion
