cat problems 207 gti
Results 1 to 7 of 7
    Tadpole mushy's Avatar
    Jul 2017
    AU
    19
    Default cat problems 207 gti
    has anyone had problems with hi flow cars after tune? my car loses power after 4800rpm...
    May 2016
    312
    That doesn't make sense? At a total guess without further information it sounds like the car is protecting itself from getting dangerously lean. Maybe a duff sensor somewhere or a just a bad tune?
    6,050
    I presume this would cause an error code or worse, but are both sensors pre and post cat defo reconnected? Wires not damaged by fitting cat?
    2003 PEUGEOT 206 GTi
    Sep 2013
    113
    If you've had it tuned and loosing power after 4.8k i'd be taking it back to tuner to investigate.
    there are too many variables. Could be bad tune, could be loose vac hose, could be a sensor, HPFP....
    PM Me for all New Genuine Spare Parts & Accessories.
    Current:
    2007 Peugeot 207 GTi
    ...Let the mods begin...
    Previous:
    2000 Peugeot 206 GTi - SOLD
    1995 Peugeot 306 S16 - SOLD
    6,050
    I just assumed the OP meant the problem happened after a new high flow cat was fitted.
    Jul 2017
    AU
    19
    getting cat change tuner figured that cat too big to much air flow has 100cpi cat getting 200cpi fitted and then retune
    Sent from my SM-G955F using aussiefrogs mobile app
    Sep 2013
    113
    Too much airflow? Im going out on a limb here and say if your actually getting it tuned correctly you would be able to run a decat and have the car tuned without the use of the o2 sensors. Alot of guys around the world run a decat without issue and tune it that way. If your intention is to run a cat then get some o2 sensor spacers and that will be enough.
    Are you getting it tuned via etuners or just the local performance shop?
    How are they tuning it?
    Current:
    Previous:
