Peugeot 207 gti rough idle
Results 1 to 20 of 20
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default Peugeot 207 gti rough idle
    Hi would like to ask if any one had a same problem like mine when I start the car it has a rough idle. Would this be the map sensor need replacement????
    Dec 2011
    Australia
    4
    How many km on yours? When were the spark plugs last changed?
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Spark plugs just got resently change itís got 105,000kms I have change coil ignition, sparks plugs , alternator belt , water pump, timing chain , just have major service on it last months.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Is there a idle air control sensor on this car ??
    Sep 2013
    113
    Is it misfiring or just idling rough?
    PM Me for all New Genuine Spare Parts & Accessories.
    Current:
    2007 Peugeot 207 GTi
    ...Let the mods begin...
    Previous:
    2000 Peugeot 206 GTi - SOLD
    1995 Peugeot 306 S16 - SOLD
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    What could be if it misfiring ?
    Or
    Just rough idle ?
    Iím not sure if itís misfiring....
    8,429
    Stick your hand behind the exhaust pipe. A misfiring cylinder will cause the smooth gas flow to stop-start. Like puffing.
    Usually a misfiring cylinder will be detected by the oxygen sensor which will bring up a pollution warning message. Misfiring damages the catalytic converter. The best thing you could do is get a Diagbox and see what the computer has stored.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Ok so itís time to change catalytic converter
    8,429
    If it is misfiring fix that first or you will waste $$$.
    With the 1.6 THP engine one cause for a misfire is a crudded up inlet valve, which ruins the air/fuel ratio for the cylinder. If it hasn't been cleaned in 100,000+ km give this serious consideration.
    Use the low ash C2 oil as used in the diesels to minimise these deposits.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    How do you clean it ???
    8,429
    Cleaning is major work, so get a computer readout and diagnosis first to be sure. You don't need regular belt changes with this engine, but cleaning has replaced that service.
    You remove the air filter and ducting, the battery, the inlet manifold, and probably the injector rail and injectors. You can now see into the inlet ports with the aid of a mirror and torch. Peugeot make an expensive softening agent, applied after the stripping process, to soften the crud which is actually "ash" residue from oil vapour burnt on. It adheres ferociously.
    Some people scrape it off using a mirror and small sharp scraper, some send it for a walnut blast. Either way it's pretty well an all day job.
    If you aren't an experienced DIY mechanic consider getting a professional who knows the engine - there are solenoids, connectors, and fixngs that are completely hidden behind the engine under the windscreen, to be worked on blind
    8,429
    Here's someone who discovered the access and view problem - 207 THP 150 - Intake manifold removal - Peugeot Forums
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Ok thank you
    Mar 2017
    Molendinar
    27
    Where are you. Some states have access to cheap walnut blast... others not so much. On the Gold Coast you can get it done for ~$300 other places up to $600. After getting mine done my car was completely different. It is a problem that becomes relly apparent at around 100-150k.
    2007 207 GTi - adding bits to make it go faster soon
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Whatís a walnut blast ???
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    All good I got it now just YouTube it to find out.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Iím located in Sydney
    inkevitch
    Mar 2017
    Molendinar
    27
    Quote Originally Posted by AAA View Post
    inkevitch
    Ahh okay. No idea then. But someone might have mentioned in these forums so search walnut blast, 207gti etc.
    Some of the garages that cater for minis will do it. The place I went to is eurotune in miami gold coast.
    In hindsight, I think it was changing my timing chain that improved the idle chatter. They need to be changed every 80k as a regular service, mine had been on for 60k, but was loose and the timing bolt was failing (it had lost its resistaence to compression so could be easily squeezed)
    It is bloody expensive to get the timing chain done and it seems like that is often the catalyst for people selling on as this is a 800-1200$ service
    Ask some other people for their advice regarding this.
    8,429
    There's a thread running on carbon (actually ash deposit) cleaning at the moment. Most normal driving will require it well before 100-150,000 km. A big job because of the disassembly. You have a choice between walnut blasting, soda blasting and hand scraping. All methods work.
    I haven't heard of anyone doing regular chain replacement. Early chains had problems and Peugeot and Citroen replaced nearly all of them. It is a slow job needing special cam setting/locking tools, and isn't done lightly. Fuel trims can give an idea of how the chain is getting along.
    Mar 2017
    Molendinar
    27
    I did it at 140k (when I bought it), it shouldn't have been due for another 20k. But I had so many things done at once so it is hard to say what improved its running. But the tensioner bolt was no longer putting the chain under enough tension.
