307 AL4 gearbox issues
Results 1 to 7 of 7
Like Tree3Likes
  • 2 Post By Matthew
  • 1 Post By salman
Thread: 307 AL4 gearbox issues
    Fellow Frogger! tazfrog's Avatar
    Nov 2011
    Burnie/Tasmania
    142
    Default 307 AL4 gearbox issues
    Greetings Puggers....when taking our 2003 307 2.0 ltr to Launceston last week
    to have central locking issues fixed...the car decided to throw a curved ball!
    80klm from home it started dropping down to 3rd for no apparent reason
    and would do it between 90-110kph.
    This happened several times accompanied by a bleep which I assume it
    has thrown a code.
    This gearbox has 187,000klm on it and has been trouble free up to know.
    Back when it was still under warranty and had about 70,000K's on it, the
    two main pressure control solenoids were replaced....the Main Pressure Modulation valve and the Converter Pressure modulation valve and after that no problems.
    As far as i know, it's still running it's original oil.
    Would the Brains Trust be able to tell me the likely cause of this problem?
    Cheers from Tazfrog
    2003 307 XSEA EW10J4 2.0 ltr petrol AL4
    China Blue.
    2018 Renault Captur 1.2 Turbo Orange/Black
    1,574
    Change oil, this is the most important thing to do in that box, solenoids etc will also play up, do oil first completely not just a top up. Might pay to get a transmission shop to pump it out / through (not a dealer). Then decide where to from there.
    Logic says that if those two parts played up at 70K km then at 180 would they need to be replaced again? Oil at every 50K km. for safety / peace of mind
    tazfrog and dcc236 like this.
    307 HDi wagon
    407 HDi wagon
    Fellow Frogger! salman's Avatar
    Jan 2005
    Melbourne Australie
    191
    scan the codes in engine and gearbox before doing anything.
    tazfrog likes this.
    Nov 2011
    Burnie/Tasmania
    142
    I am waiting on results from dealer tomorrow or Tues...before any action is taken.
    I had planned on doing the oil....a complete change will take about five empty/re-fills
    to get it all and propose to use Castrol Transmax-Z which has the full ZF 71124 spec.
    I have used this same oil in my 1998 Jaguar XJ8 4.0 ltr which is fitted with the ZF 5HP24 trans.
    Cheers from Tazfrog
    China Blue.
    1,574
    Delete this,
    Its a good fluid are you sure its for the gearbox however?
    It is a good auto box fluid, wonders never cease, I am a complete auto box newby just got a 407 6 speed with much the same sort of issues if you do not look after it.
    Its in my power steering box (land cruiser) and soon 205. Castrol VMX80 is my manual 80 series oil.
    307 HDi wagon
    407 HDi wagon
    Nov 2011
    Burnie/Tasmania
    142
    Quote Originally Posted by Matthew View Post
    Mathew....I believe that like all things with moden automatics, they only have a certain shelf life
    and I will be changing them if it's deemed necessary.
    Cheers from Tazfrog
    China Blue.
    Nov 2011
    Burnie/Tasmania
    142
    Delete this,
    Transmax-Z most certainly is....look up their web site....I prefer it to Penrite....even though I use Penrite oils
    for everything else.
    Cheers from Tazfrog
    China Blue.
