Peugeot 807 Antipollution Fault
Results 1 to 7 of 7
    Tadpole KristianBrit's Avatar
    May 2018
    United Kingdom
    4
    Default Peugeot 807 Antipollution Fault
    Hi, this is my first post. I own an 807 2.2 hdi. Iíve only had it a few weeks, and the previous owner explained that the EML intermittently comes on with an Antipollution message but doesnít effect the cars performance. Since then Iíve established that itíll go in to limp mode randomly so I have to stop the car and turn engine off for a few minutes, to which itíll work as normal again. They also said that the garage they took it to checked for faults and found none, and concluded it could be a dodgy sensor somewhere. Does anyone have any advise as to what could be causing this occasional EML illumination. Could it be a DPF?
    Thanks in advance.
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    455
    A failed throttle body has the effect of affecting the the car's performance by putting the car into limp home mode. My advice is to check out this item which is located at the centre front of the engine. What is the year of manufacture of your vehicle or more importantly, what is the engine code?
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    901
    More than likely the old 2.2 check vacuum lines to egr turbo etc known to fail
    May 2018
    United Kingdom
    4
    Quote Originally Posted by Ceenine View Post
    My car is 2005 but Iím not sure on engine code. Can source this though.
    May 2018
    United Kingdom
    4
    Would that cause the antipollution fault too? As I said, there are no codes to accompany this message, so not sure what it is.
    Jan 2014
    Ferntree gully
    20
    Quote Originally Posted by KristianBrit View Post
    Howís the fuel filter condition?
    Probably should put something clever here..
    oh well
    May 2018
    United Kingdom
    4
    Not sure about condition of fuel filter. However I could definitely find out if itís been replaced from service history.
