Catalytic converters - using a 405 one for a 306
Results 1 to 13 of 13
    May 2016
    312
    Default Catalytic converters - using a 405 one for a 306
    I need a new cat for my 306 XSi (XU10J4R 16v engine)
    I have found EAI are selling a NOS cat for a 405 2.0 XU10J2 engine - I believe an 8 valve engine. It's $99 - seems like a reasonable chance it'd work just fine.
    Is there any reason I couldn't cut and weld this into my 306?
    Thanks!
    May 2016
    312
    Ok, no immediate responses. Must be a dumb question.
    How about something like this Magnaflow weld in Cat with 2.25" in/outlets?
    https://www.ebay.com.au/itm/Magnaflo...8AAOSw14xWOYTs
    1000+ Posts Beano's Avatar
    2,963
    This scenario must have been thought about before. Perhaps Mr Google could provide enlightenment ?
    Or a quick call to a muffler shop ?
    May 2016
    312
    Quote Originally Posted by Beano View Post
    You'd think so, but rather than sifting through endless threads from the UK about "sik" 3" systems etc and nothing specific I thought I'd ask here - most responses here come from people with first hand experience.
    I did call my local exhaust shop. Quoted $550 for a universal fit cut and weld with no specific info on the cat used.
    I've spoken to my mechanics workshop and they are happy to organise welding in a new cat if I provide it. So I have taken a chance on the magnaflow fitting. The new old stock 405 cat may not be up to scratch after sitting on a shelf for a decade.
    894
    For $99, I'd take the punt if you have someone who will do any welding mods cheaply. Easy enough to change flanges etc if you already have the welding gear.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    6,215
    I have a new Magnaflow on my 206 and it's excellent. One thing about the NOS one - it might be a ceramic substrate cat which can fracture, where the Magnaflow is metallic substrate.
    2003 PEUGEOT 206 GTi
    May 2016
    312
    Perfect, that's what I was hoping to hear. Hopefully I can have it fitted up next week and see if that and the new O2 sensor smooths out the engine a little.
    Fellow Frogger! blahblah's Avatar
    Perth
    306
    Quote Originally Posted by lowpugV2 View Post
    I used something similar on my 306 XSi - $130 to have an exhaust guy weld it in. I covered it a thread called ‘My 306’ or similar with pics. Works a treat!
    Perth
    306
    Quote Originally Posted by blahblah View Post
    Here’s a link - the pics may be of interest.
    My 306
    https://r.tapatalk.com/shareLink?sha...9&share_type=t
    May 2016
    312
    Oh yeah, that's exactly what I'll be doing. I am also fitting a new o2 sensor but I'm taking a gamble with a well rated eBay item. $41 vs $159 I was quoted for the Bosch. I'll probably end up buying the Bosch....
    Mar 2005
    316
    I had a Bosch one fitted to my 205SI, was $110 including labour!
    May 2016
    312
    Right, well pays to shop around then. I had just spoken to a local exhaust shop. The part direct from Bosch cost $124. Will see how the eBay experience is...
    Perth
    306
    Just seen this - I picked up a Bosch direct fit sensor (plugs straight in) for $100 delivered off eBay.
