Peugeot 307 IAT sensor
Results 1 to 2 of 2
    Apr 2018
    UK
    7
    Default Peugeot 307 IAT sensor
    Hey guys I had the dreaded Antipollution Faulty on my Peugeot 307 1.6v 2007 petrol. I took a reader and said this:
    P0113 Permanent Fault
    Intake air temperature signal short circuit to earth
    Then the Antipollution Faulty message disappeared after the next start of the car.
    I just want to know how to address this? Do I need to change the IAT sensor? Is it an easy job? And where is it located? Cheers guys.
    Sent from my SM-G930F using aussiefrogs mobile app
    Jan 2015
    121
    The air temp sensor is built in to the manifold pressure sensor which is on the front of the inlet manifold towards the timing side and has a breather pipe next to sensor it is held on by an 8mm bolt very easy to get to also check the wiring near to the connector Iíve seen them broken before
