505 air con-can they be upgraded?
Results 1 to 8 of 8
    112
    Default 505 air con-can they be upgraded?
    Hi
    We have an 85 505 with air con. Its had a couple of regases over the years-It works but its never been great.
    Just wondering if anyone has upgraded a 505 air con system or knows what it would need?
    Rob
    Fellow Frogger! Codman's Avatar
    Feb 2015
    Skye, Victoria
    512
    Would be interested to hear anyones ideas on this, a one of mine will need to be sorted, the other of the two 505 wagons, an 88, has insane air-con, the kind you wish would not be quite so intense so i think if its working as it should be there is no need.
    Current -
    65' 404 Sedan,
    88' 205 GTI/16V
    92' 505 Custom Turbo Wagon
    92' 205 SI
    88' 505 GTI Wagon - PARTING OUT PM ME
    Gone -
    04' 206 RC (GTI180)
    2 X 405 STI,
    405 MI16
    98' 406 Coupe
    406 2l
    91' 205 SI
    306 Style,
    3 X 306 GTI6
    1000+ Posts Beano's Avatar
    2,870
    Try cleaning the leaves off the front of the evaporator, inside the passenger side of the engine bay.....they have been sucked in there and are restricting the air flow. You will have to take off the firewall insulation and then the large rubber boot, and get in there with a wire brush and vacuum cleaner. It will hurt your hands a bit to manipulate them in a confined space.
    You'll be amazed at the results.
    Jun 2017
    44
    While we're talking aircon, any one have any info/tips on reinstalling an aircon system? Mine has been removed at some time in the past and it'd be real cool to have cooling next summer.
    Maybe this is the last time I'll have to fix it...
    112
    Thanks Beano
    I'll have a look
    rob
    2,870
    You can assess whether that might be the problem by how much air flow you currently have.
    BTW, of course the wire brush needs to be one of those small and slightly soft ones.
    It's a bit of a bugger of a job to get your hands in there, but it can be done. It's not my own idea...a Pug specialist showed me how.
    1000+ Posts Gamma's Avatar
    Picton NSW
    1,413
    Talk to Bill McNamee in Canberra.
    He sorted my 86 505 GTI A/C.
    I think it was a matter of getting a compressor from a 405 and a drying canister so modern gas can be used.
    Not hard to do......
    /// 1986 SII 505 GTI
    2003 T5 307 HDI
    2013 LandRover90
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    613
    I'd say a compressor from a modern Korean or Japanese car that have freezing cold A/C with almost zero effect on fuel consumption.
    The 504 compressor puts quite some load on the engine.
    Quote Originally Posted by Gamma View Post
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
