ECU remap
Results 1 to 21 of 21
Like Tree3Likes
  • 1 Post By cam85
  • 1 Post By Demannu
  • 1 Post By speaksgeek
Thread: ECU remap
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default ECU remap
    Hi would like to us where in Sydney I can get my ecu remap for my Peugeot 207 gti ? How much do they normally cost? And a place that can do them cheap?? Thank you
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,248
    AAA
    Cheap and reliable wont come in the same line. Neither will quality. Not AAA quality anyway...
    Are you wanting more power?
    speaksgeek likes this.
    Sep 2013
    113
    etuners are your best bet
    PM Me for all New Genuine Spare Parts & Accessories.
    Current:
    2007 Peugeot 207 GTi
    ...Let the mods begin...
    Previous:
    2000 Peugeot 206 GTi - SOLD
    1995 Peugeot 306 S16 - SOLD
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    I’m changing my catalytic converter n I might need to remapped the ecu.
    brisbane
    2,853
    If just changing the cat you wont require a remap.
    jr20516v
    Now:
    RS CLIO 3, Exige SC [modded], 205 Si.
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2
    brisbane
    2,853
    Forgot to add a remap price.....they are usually around $900 to $1400
    jr20516v
    Now:
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Ok wat about if I replace it with a down pipe then I will need a remap for ecu ???
    brisbane
    2,853
    Mmmm....when i replaced my down pipe [dump pipe ] on my Gti-r from memory it didnt need a re-map however the Pug may be different....and boy what a difference it made........10kw atw in an easy to fit $50 part.
    jr20516v
    Now:
    Nov 2003
    Bondi
    3,248
    Shouldn't need a remap with just the DP. A complete system would make a nice difference.
    Dec 2002
    2,491
    I think the 207 GTi has both pre-cat and post-cat O2 sensors. If so, removing the catalytic converter (which is very illegal by the way and carries a fine of up to $22,000 if you get caught) without an ECU software edit will cause an error and possibly reduce engine performance.
    Scotty
    Melbourne - Dandenong Ranges
    2014 Peugeot RCZ - 'Remy'
    brisbane
    2,853
    Beg to differ Skotty. :} There is no law against reducing 2 cats down to one....as long there is at least one. [most cars have only one ]
    The 207 Gti setup by the O.P. sounds similar to my Colt Ralliart....2 cats....remove one....re- position the 02 sensor ensuring the 02 sensor is AFTER the cat converter....also wise to put a spacer in to avoid CEL'S. Works a treat.
    PS: this is for a complete exhaust system change which would make the 207 really get up and go if done right.
    jr20516v
    Now:
    Dec 2002
    2,491
    You might want to check your source on that one JR - any replacement catalytic converters and sensors must be in the same configuration and exhaust flow location as original. Take a look on the EPA website.
    The intent of the rules is to retain the original emissions performance of the system. If you change anything that will impact it, you will need an engineer to provide test results demonstrating that it still meets the design emission standards for CO, CO2, NO2 and HCs. The reality of course is that very few people actually go to this level, but the level of inspection and number of people being caught for violations is on the rise.
    However - back on topic - I think the 207 GTi has just one catalytic converter, but two sensors. The signals from the two sensors will be different before and after the cat - and if the cat is removed, the ECU can tell and will throw a fault. There are ECU edits known as 'second O2 sensor elimination' and also 'interceptor' style boxes to fool the ECU.
    hypermiler likes this.
    Scotty
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Thank you everyone for your help but I asked the mechanic if I change to downpipe it will trigger the ecu n lights will pop up n lose power. But If I change it with the same catalytic converter I won’t have to re map it or do anything to it.
    I hope this is true.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default ECU remap
    I’m planning to buy brand new catalytic converter from Europe they have heaps of part there. I have one company selling $450au including postage to Sydney. What you think everyone ???
    8,884
    What's wrong with the present one?
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Turbo boost keeps cutting out n I got the car scan it came up catalytic converter.
    Sep 2013
    113
    i would suggest that you change your O2 sensors first, then the cat. Also you could look at highflow units from the UK which is another option.
    As for the removal of the Cat with a straight down pipe, you can do it but then you will need to buy a couple of these (or similar):
    https://www.deaperformance.com.au/p/...FIX-CAT/OSF180
    One for the top o2 sensor one for the bottom - these have mini cat converters built in so you screw these into your o2 sensor then into your down pipe and happy days. I've used them successfully on many cars (mine and my friends) and they are great. As mentioned it is illegal if you get caught but its a very hard thing to get caught on as you have to go and take a test, in which time you could swap it out with your old cat and be fine.
    Current:
    Previous:
    874
    This is fairly true in Melbourne, where EPA testing give you notice, and is rather more slack.
    For NSW, the police will escort you direct to a testing centre when they are doing a blitz.
    Quote Originally Posted by hito View Post
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Sep 2013
    113
    Quote Originally Posted by speaksgeek View Post
    Just another reason why Melbourne is the superior city , personally id still do it - Your in a Peugeot, what are the chances that you will get pulled over at all.
    Current:
    Previous:
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi hito ,
    I have already changed both 02 sensor top n bottom but will try this for sure n hope it will stop the boost cut out.
    Thank you
    Sep 2013
    113
    Quote Originally Posted by AAA View Post
    Hi hito ,
    Thank you
    Anytime let me know how you go
    Current:
    Previous:
