Peugeot RCZ
Results 1 to 20 of 20
Like Tree17Likes
  • 1 Post By MarcusG116
  • 5 Post By SilverGTi_6
  • 5 Post By cam85
  • 5 Post By Valentia
  • 1 Post By dmccurtayne
Thread: Peugeot RCZ
    Jun 2017
    29
    Default Peugeot RCZ
    Hi everybody
    just thinking about when it eventually comes time to replace my 306 and thinking about a few different cars. Renault Megan RS 250, Alfa Giulietta QV and the Peugeot RCZ are the main three.
    Can I ask people that own RCZ’s what they think or what to look out for. I know they stretch timing chains. How would you check for stretch without taking off timing chain case? How reliable are they? what goes wrong? Fuel economy? Servicing?
    Marcus
    SilverGTi_6 likes this.
    Fellow Frogger! SilverGTi_6's Avatar
    Apr 2005
    819
    Default Peugeot RCZ
    Hey mate, I've owned an RCZ for just over a year now. Surprisingly brilliant car to drive. Lots of grip, great brakes and the engine has a nice power curve. Interior is a nice place to be. The boot is ginormous for a two door coupe - I fitted two lawn mowers in mine the other day without even folding the seats down!
    Fuel economy is fantastic. I get about 5.9 on the highway and between 6.8-7.2 around town, and that is not driving economically by any means.
    The RCZ actually won Top Gear coupe of the year in 2010 (even though they hate Peugeot's in general).
    I had to replace the thermostat housing (stupid plastic thing) and I believe my high pressure fuel pump may be in need of replacement shortly (to be confirmed this weekend). Both of these are unfortunate (and I don't believe ridiculously common).
    If the tensioner / chain needs replacing it'll sound like a diesel on startup (when cold). From what I have read it's pretty uncommon on the 2011+ vehicles (no probs with mine).
    dvr, Doush_504, CC207 and 2 others like this.
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Citroen C4 VTS
    Previous
    Lotus Sport 111, RCZ, 205 GTi, Volvo C30 T5-R, Honda S2000, 206 GTi180, Lotus Elise 111R, 205 GTi 6, Manual 406 coupe, 306 GTi 6, 405 MI16 (twice!), 505 GR
    8,074
    The timing chain problem occurred wth early 1.6 THP engines, and most if not all will have been replaced by now. The same goes for failures in the thermostat housing. These parts were redesigned. Some early engines had a flaw develop in the high pressure pump metal.
    There is no timing case as the chain is internal to the block and head. Being direct high pressure fuel injected, like all such engines, with mileage the inlet valves clag up and need cleaning.
    brisbane
    2,853
    Dont go the Alfa...........you will need shares in a mechanics workshop and boxes of Prozac. Been there done that [the Alfa that is }
    jr20516v
    Now:
    RS CLIO 3, Exige SC [modded], 205 Si.
    Previous: Honda EP3 Supercharged , 205 x34 [ including MI16 TURBO, 8v TURBO, CTI, 16V+TB's, 8V+TB's,] Fiat X1-9 X3, Beta coupes x5, Lancia Gamma coupe, GTI-R, Corvette C4, Fiero x5, Alpine GTA turbo, r5 GTT Dimma, 2cv ripple nose, Lotus Elise, 205 Dimma TT, Cliosport 172.x2
    PDJ
    PDJ is offline
    Fellow Frogger! PDJ's Avatar
    Central Coast NSW
    191
    RCZ = Aldi TT
    WD-40'll fix It! If it don't, use a big hammer
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,248
    Except it can actually go around a corner and you dont look like a dickhead driving it! And its cheaper and looks way better! Like a big Jaw eating the road...
    Fellow Frogger! Valentia's Avatar
    Jan 2011
    367
    I bought my RCZ as a demo in 2012 with 120km on the clock. 18km of those was on my test drive. It now has 112xxxks on it. Servicing from Peugeot is expensive. But as they are now out of warranty, you can take it some place good for a better price.
    In the time I have had mine, I have had, 2 front high pressure fuel pumps, the fuel rail, and the thermostat replaced under warranty. The thermostat was then bypassed to fix the issue of it failing again. Otherwise that was it for new parts. However, about 2 years later, so now, I am getting fueling issues once more. So it looks like the Front HPFP/Fuel rail need to be changed again, possibly the rear fuel pump. Been quoted;
    Front fuel pump: $ 1465.07
    Rear fuel pump: $ 745.04
    Fuel Rail: $ 572
    From Peugeot.
    EAI was $800 OEM or $1200+ for genuine. And did not get other prices as that is all they gave me when I called.
    The tyres that are on the car are a weird sizing, you don't get a lot of choice if you stay stock, and the choice you have is expensive. I went the next size up and saved $400. However at full lock at slow speeds there is a slipping and banging from the tyres which gets annoying.
    The engine does tend to use some oil. After 10,000ks it will be down a bit. So I do oil changes every 5,000ks now.
    Around town I can get around 700km to a tank. So about 650ks before refueling. If I do a Canberra to Syndey trip I can get there and back without refueling. I use it to go to the snow quite often, and with the back seat dropped I can fit in a 181CM snowboard and a set of 175cms skis and all gear with plenty of room left over. It can happily transport a bicycle.
    I find it a comfortable car to drive as it has quite a lot of adjustment in the seat and steering wheel. The visibility is good, once you learn to look through the tiny side windows, and where to place the car for corners. It is wide and you sit in a little bit. My elbow sits on the window ledge, so for car parks you have to get close to ticket machine, or else do the door open.
    But in my 112xxxks and 6 years of owning it, I have loved it. It has only had an issue once when I needed it (was waiting for the HPFP to come in and be replaced under warranty). I have had it at a track day with a bunch of RX-8's which was very fun. Not found a better car to replace it with. Looking at keeping it for as long as it keeps going. All my friends rag me for owning a Pug, yet in the pug I can take corners better than a friends well worked STi.
    Side note, if you want to Mod it, there is not a great deal of options available for you. But mine is stock (bar the next size up tyre) and is still dang fun.
    2012 - RCZ.
    1994 - 405 Mi16.
    1974 - Dnper 650 sidecar.
    1997 - Honda CBR1100XX Superblack bird.
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    923
    Why are they replacing the fuel rail I have never done one and the sensors don’t fail
    Berridale likes this.
    Jerangle
    751
    Could be the dealers are getting up you?
    Jan 2011
    367
    The first time the HPFP and Fuel rail was changed was under warrant, so cost me $0. So Was happy with that.
    The ECU was scanned for errors with Bill McNamee. It codes are very unhelpful so it is bit of a guessing game as to which of those 3 parts is borked.
    So I got prices for all 3 of them. Does not mean that all of them will be done.
    2012 - RCZ.
    1994 - 405 Mi16.
    Apr 2005
    819
    Can confirm, just replaced my HPFP at 70k. Seems to be a relatively common issue on direct injection engines unfortunately.
    Lotus Evora
    Peugeot 308 GTi
    1966 Volvo 122s
    Citroen C4 VTS
    Previous
    Jul 2013
    923
    Yeah the hp fuel pump but never the rail the two pistons in the pumps start to seize also the regulation valves fail I have never done a rail
    Jul 2013
    923
    What codes do you have
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    613
    Try using an oil with BMW LL-01 certification ... you'll notice the improvement yourself
    Quote Originally Posted by Valentia View Post
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Tadpole 207ccRipper's Avatar
    Aug 2018
    Victoria
    12
    What were the symptoms of the fuel pump failing. Cheers
    Jul 2013
    923
    Misfire on opposing cylinders chugging when cold and miss under load
    Aug 2018
    Victoria
    12
    Coils and or plugs.
    Fellow Frogger! 207cc Sport's Avatar
    Apr 2016
    Gold Coast Hinterland
    213
    Quote Originally Posted by Doush_504 View Post
    Castrol 5W30 full synthetic is BMW LL-1 certified.
    Recommended.
    The French Tart… 207cc Sport THP150 and now a RCZ Mk2 THP200
    Apr 2016
    213
    Peugeot RCZ's from 2013 onwards had lots of engine improvements.
    Jul 2013
    923
    What do you mean coils and plugs
    Fix it right the first time
