Replacing Halogen Globes with LED Equivalents
Results 1 to 12 of 12
Like Tree3Likes
  • 3 Post By Ken W
Thread: Replacing Halogen Globes with LED Equivalents
    Member sheusz2000's Avatar
    Mar 2011
    Newcastle
    116
    Default Replacing Halogen Globes with LED Equivalents
    Hello Brains Trust.
    My 3008 has halogen headlights with HB3 globes. I'd like to replace them with LED globes.
    My question is, is this a straight swap or is it going to be more problematic than that? Are there any potential issues with the swap?
    307 - 2003 XSE 2L Petrol Manual
    3008 - 2018 Allure 1.6L Petrol Automatic
    18,038
    My experience is Leds are a much bigger light source.
    This screws up the focus and reflector operation.
    with apologies to Judy Grahn
    8,207
    They are best in non-focused lights. You'll also need a module in line to fool the computer or you will get errors logged.
    1000+ Posts Ken W's Avatar
    North Brisbane
    1,856
    There are regulatory issues with fitting LED bulbs to headlights which have been certified to meet Design Rule requirements. Here is RACQ take on headlight upgrades. I havn't asked the question about what can be done with pre-ADR headlights.
    https://www.racq.com.au/cars-and-dri...ely/headlights
    Cheers, Ken
    hypermiler, Dano and Kenfuego like this.
    8,974
    Don't do it, the ones I tried looked nice and bright from the outside but were poor on low beam and non existent on high.
    888
    Most of the issues have been raised already. In addition, most modern cars will measure current draw to detect failures.
    If you install LED they will probably draw too little current and cause a fault, unless you also use an inline resistor which defeats one of the purposes for using them, which is the reduced power consumption.
    Headlight reflectors are very carefully designed for the specific bulb type. Led replacements don't usually match quite right.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Mar 2011
    Newcastle
    116
    Thanks all for your input. I've decided to save my money and the heartache.
    1000+ Posts driven's Avatar
    Apr 2005
    1,312
    Don't dismiss LEDs
    If you want LED with max light you need to get the best
    https://www.autobarn.com.au/el26655
    Just $180 a pair for 2000 lumens and work properly, and draw 25 W
    Truckies use this brand
    Std bulbs are about $25 pair and draw 60 W have relatively poor light
    888
    Also not ADR compliant, so not legal on road.
    I reallywant some LEDs in my cars, butuntil they are actually legal, I'm holding off.
    Don't dismiss LEDs
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    COL
    COL is offline
    A110 COL's Avatar
    Van Diemen's Land
    3,803
    Some of those lights on trucks are very intense light and are hard on the eyes when they are approaching.
    From my experience of using a LED light bar is that LED lights have a very narrow spread of light.
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    Fellow Frogger! andrepug's Avatar
    Victoria
    439
    So to sum up - buy a new car with LEDs already fitted as standard.
    888
    Quote Originally Posted by andrepug View Post
    If LED headlights are your deciding feature, yes.
    If you want to improve your high beam, then get a lightbar. I found a spot for mine behind the grill, so it's pretty discreet (on my wagon, not 206)
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
