peugeot expert wont start / run
Results 1 to 19 of 19
    Nov 2016
    ballarat
    11
    Icon4 peugeot expert wont start / run
    we just brought a peugeot expert as a non runner and have no history of the car its a 2.0 l hdi 2009 with the seimans injection system it started but run rough and blow white smoke now it starts and runs for a second and then cuts out I only have a cheap diagnostic tool and come up with generic code p1351 does any one have any ideas or recommendations for a peugeot scan tool
    Fellow Frogger! andrepug's Avatar
    Victoria
    439
    It probably uses the DW10 engine common to many Peugeot and Citroen sedans so search what similar issues people have with those cars.
    eg; Poor starting and error codes P1351 and P1351P - Peugeot Forums
    Same for code readers;
    8,207
    The code is open circuit at the glow plugs. The software needed is Diagbox - not officially released, and available online only.
    Nov 2016
    ballarat
    11
    Default hdi
    yeh funny it comes up with a code for glow plug didn't think hdi had glow plugs have seen that on line also will keep searching thanks for your reply
    there was a fuel filter in. the back when we bought the van and a full tank of diesel so I'm thinking the previous owner thought there was a fuel supply problem
    thanks again
    Nov 2016
    ballarat
    11
    thanks will look it up
    Jul 2004
    799
    I have experienced this first hand on an expert van, White smoke and only ran for a second. Had a bent conrod. you could try a compression test. Most Dw10's are getting around with a few (if not all) dead glow plugs, won't cause the car not to run.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
    8,207
    Assuming the RHR motor - check your VIN for these letters - here is the location of the plugs.
    peugeot expert wont start / run-glowplugs.jpg
    Item 9 Bougies de préchauffage
    It isn't a cause of major trouble unless it's very cold down your way. There are probably other faults. White smoke is unburnt fuel.
    Jul 2013
    Newcastle/ central coast
    1,235
    Stop doing anything else and disconnect the egr valve where it’s pipe runs to the intake should start
    Nov 2016
    ballarat
    11
    Quote Originally Posted by dmccurtayne View Post
    thanks I will try that tomorrow
    Nov 2016
    ballarat
    11
    Nov 2016
    ballarat
    11
    tried starting it again tonight than cycled ignition / glow plugs and it started. it was sluggish to rev up and blow sot and white smoke out the exhaust and it also blow some smoke from out behind the engine i am now wondering if the exhaust could be that blocked stoping it reving given that i have no major fault codes thank in advance for any imput
    Jul 2013
    1,235
    Did you take the egr pipe out
    Nov 2016
    ballarat
    11
    yeah I did got it started run rough no power and after a 5 minute drive got better so might go for a longer ride tomorrow
    Jul 2013
    1,235
    It will need an egr valve then
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    353
    Being a 2009 model, it should have a DPF, so there may be a problem there.
    How many K's has it done. In theory it should last over 200,000k's, but depends on the driving conditions and other factors.
    Jan 2014
    Coffs Harbour, NSW Australia
    273
    Hi to all, was googling for clues on 407 HDi going over temp whilst maintaining a healthy speed up Moonbi ( a long climb north of Tamworth) when I came across an interesting account re sorting a 307 with 2.0 HDi (RHR) that blew lots of white smoke etc. If it may help y'all it was Professional Motor Mechanic at http://pmmonline.co.uk/technical-com...ugeot-307-hdi/
    Hoping it helps now or in the future; cheers
    8,207
    I had a problem with that link. A site search for "Peugeot 307" on the home page found it.
    Oct 2014
    Brisbane/Australia
    361
    Doesn't white smoke = water?
    I'm pretty sure if your glow plugs aren't working, it will not do a dpf burn. Might be reason for lack of power after starting, ie. blocked dpf.
    You more than likely have multiple issues that need resolving.
    8,207
    In a diesel white smoke is normally hydrocarbons. A bit blueish if partially burned oil, quite white if unburnt fuel. In days gone by nearly every indirect injection diesel blew white at a winter start, but it quickly cleared as the head warmed.
    I remember being stopped by police for blowing smoke as I started and pulled out, in the 70s. I explained it would clear and they waited and watched until it did!
