Catalytic converter
Results 1 to 16 of 16
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default Catalytic converter
    Hi my Peugeot friends,
    I would like to ask where can I get a catalytic converter for my Peugeot 207 gti 2007 model ??? Would like to know if anyone knows anyone that can replace them in Sydney NSW ????? Thank you
    Regards
    AAA
    8,207
    You could try EAI at Thornleigh for the converter. If they have one it is a courier away. Changing it isn't complex, but if you want a mechanic recommendation it would help to know where you are.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi seasink ,
    I rang them up they said they donít have one and they canít get hold on them as well???
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Would you know where else I can get them ??
    888
    You could get a muffler shop to weld in a new one. I had an exhaust built for the 206 with a higher flow cat. They added ports for the two oxygen sensors same as stock, and it didn't cause any issues.
    1984 505 Executive Auto
    206 GTi 180 - '804 Cat Cams, Jenvey DBW 48mm ITB's, Emtron KV8 ECU, HP Electronik PDM, AIM MXS Dash, Custom Wiring Harness. AST Camber Tops & Coilovers, -2deg camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, PeugeotSport Baffled Sump, Oil cooler, Quaife LSD, E85.
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Phillip Island - 1:55.9
    NŁrburgring - 10:23.ish (Fiesta ST)
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Sep 2003
    North Parramatta
    3,973
    I would have thought an exhaust place would be able to help.
    Failing that, the part number (item 10 in pic) is 1706F6 or 9682490780. You should probably order a new gasket (item 12) as well.
    It's a part used on many similar models with that engine (not sure about the R56 Mini, though).
    Look on eBay or try ATwins, DAPCO or ASV, if EAI are no help.
    It's possible to get one from a wreck but a new one from O/S may end up just as cheap
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Jul 2013
    Newcastle/ central coast
    1,235
    One off setup get sh whatís wrong with it
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi speaksgeek where did you get your one done? How much did it cost you ? Thanx mate
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi slc206
    Yeah I will check it out
    Thanx mate
    888
    In Melbourne, and not very much (<$400 maybe?). It was a few years ago.
    My more recent exhaust, full stainless custom tig welded job front to back was $1200 (no cat though).
    Quote Originally Posted by AAA View Post
    Sandown - 1:31.5
    Winton - 1:40.2
    Wakefield - 1:13.5
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    613
    Would anyone know the meaning of " and age > 3 " ?
    I heard that it's a cheaper part but still original, is this correct ?
    Quote Originally Posted by SLC206 View Post
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Speaksgeek
    Iím from Sydney any one know?? Thanx mate
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi slc206
    That part number is from Peugeot 308 is this correct
    Feb 2018
    Australia
    363
    Hi
    I would also suggest trying any muffler fitter. I tried to buy a cat for a 2002 Golf. Auto parts shop had to ring around to locate a supplier and was quoted $1200 or something like that. Tuffy Mufflers said $700 fitted and they didn't take an hour to find one. Seems they know where to get them.
    Andy
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Hi 1972ren
    Ok thank you I will give them a ring tomorrow
    Cheers mate
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Cheers everyone I found one that can replace my catalytic converter.
    Regards
    AAA
