Clunk in front left somewhere
Results 1 to 25 of 38
Like Tree3Likes
Thread: Clunk in front left somewhere
    Jun 2017
    29
    Default Clunk in front left somewhere
    Hi everybody
    i have done a bit of reading and seems like others have had clunks in the front end and usually itís the bottom arm bushes.
    I am getting a knock which is most noticeable when taking off or coming to a stop. Itís just a single clunk. I would award it was the gearbox month but itís perfect. Have had mechanics look over it and they canít see anything. Iíve replaced all front bushes except for sway bar but they are fine. I have new shocks as well as new discs and pads. Other engine mounts are fine. CV joints feel ok there is no knocking when cornering. I have also replaced the exhaust coupling at the exhaust manifold as that was knacked. Still no good. The car has done close to 400,000ks so going well but this is very very annoying. Anyone have any other ideas???
    thanks
    Marcus
    Jun 2017
    29
    Oops a few auto corrects that went wrong.
    ...swear it was gearbox Mount....
    8,074
    What model is it?
    FWD cars have 3 engine mounts to take the torque reaction from the wheels - don't forget the bottom one near the drive shafts.
    If it's high up, I'd take a look at the bearing at the top of the McPherson strut. They thunk when worn and the horizontal load changes direction at start and stop.
    May 2016
    309
    I'm guessing engine mount too... Depends on what car though!
    Jan 2014
    Coffs Harbour, NSW Australia
    252
    Your symptoms sound a bit like an issue I am about to fix. If you can reveal what it is that you drive there is a chance of moving forward.
    1000+ Posts Beano's Avatar
    2,870
    I just looked at his past posts and he has a:
    "306 sedan XT with the 2litre twin cam 16v 2000 model. It's been a great family car and coming up on 380,000k's. Still goes really well".
    Jun 2017
    29
    Hi yes sorry it’s a 306 2litre 16v sedan
    Fellow Frogger! luthier's Avatar
    Northern NSW
    984
    You can't tell by looking to evaluate the swaybar links. Once you pull them out you can see if they are not tight. Any slop will cause nasty clunks. I've just replaced both sides on my 406HDI and I also did the lower balljoint on the driver's side. That is also hard to diagnose as you need to get a jemmy bar in the right spot while it's on a hoist before you can see movement. Best diagnosed at a Pug repair shop. Coles in Lismore diagnosed mine. They are superb at finding stuff that is not easy for the home guy. Now I have No more clunks.
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    923
    Lower control arms get noisy as well thanks for the guessing game first up 😂
    Jun 2017
    29
    Hi thanks for that yeah lower arms are all brand new. I haven’t done drop links will pull off again and check but they feel ok. Only things then I guess are engine mounts? They look fine and with pry bar and rocking engine still look ok. Maybe worth just changing them anyway?
    It's how I roll...Brisbane
    32,396
    ..is the family cat accounted for?
    5,933
    Some have reported the driver's side upper engine mount tearing out of the body on the 2 litres. But I assume you mean left side of the car as you sit in it rather than left as you're looking at the engine?
    2003 PEUGEOT 206 GTi
    1000+ Posts djvu205's Avatar
    1,367
    Brake caliper?
    Jun 2017
    29
    It sounds like left ie passenger side.
    DJVU brake caliper? Not bolted on?
    1,367
    Quote Originally Posted by MarcusG116 View Post
    Could be loose mounting bolts but unlikely. Depending on caliper Style sometimes slide pins become worn and the caliper will clunk when braking and possibly when taking off. Worth a look if you have checked everything else.
    Alain likes this.
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,248
    Droplinks 9 times out of 10
    even if they 'feel ok' there can be wear in them.
    There cheap and easy to replace. 5 minutes per side
    Alain likes this.
    Jun 2017
    29
    Ok so I have changed the drop links. The old ones felt fine but bought new ones so changed anyway. Still not fixed!!!
    could it be CV joint maybe? There is a bit of play when in gear and rock wheel back and forth but not a clunk like my sound? I’m really at a loss on this one.
    Brake caliper has a tiny bit of movement on sliding bolt but don’t think it’s that. Any other ideas??
    8,074
    Ok. 306, high mileage, not drop links. That only leaves the bushes on the bottom wishbone/control arm, and the top strut bearing. Check that one. I have seen them shot at 50,000 km.
    Jun 2017
    29
    I didn’t change them when I replaced the strut so I will look at them. Wouldn’t you see the strut move if it was gone though?
    Jun 2017
    29
    I have done bottom arms
    8,431
    My money sez it's the callipers. It may not feel like there's much play but they don't need much to clunk like that. Have someone in the car apply the brakes with the car on jacks or stands, grab the wheel and try to turn. You'll see what's what then.
    Or stop the car right next to an assistant with good ears. They should be able to tell if the clunk comes from the top of the strut or somewhere lower, like the calliper.
    ACHTUNG ALLES LOOKENPEEPERS
    2,870
    ^ Good advice.
    Jun 2017
    29
    I will get my wife to drive it and stop etc and I will listen. I really think it’s the gearbox mount but it looks good and can’t get it to hit using pry bar! Will see if I am hear where it come from. Will let you all know what I find
    2,870
    Good luck with that. Sometimes you can tell exactly where noises are coming from, sometimes they travel around and appear to be coming from other places. A very experienced Pug mechanic told me this on at least two occasions when I was tracking down noises.
    He had a couple of amazing stories of experiences to illustrate this but I can't remember them.
    You'd think that the pry bar would reveal movement....that's what they use in garages. And I have been told by a couple of garages using this method that certain bushes were worn out when they were worn but still serviceable.
    Good idea though to have your wife drive, but whilst you contort around upside down in the back seat with legs flailing I hope nobody thinks you are being kidnapped.
    8,431
    Quote Originally Posted by Beano View Post
    Perhaps my point was not clear enough. The person listening tp the noise needs to be outside the car, that is why I said:
