306 air conditioning/climate control
Results 1 to 25 of 26
Like Tree3Likes
Thread: 306 air conditioning/climate control
    May 2016
    311
    Default 306 air conditioning/climate control
    I'm sure it's been covered but search has failed me.
    Is there a bullet point checklist when testing a 2001 306 xsi AC system?
    Apart from a leak test and pressure switch test are the other electrical components likely to stop the system working?
    Jul 2013
    Newcastle/ central coast
    1,235
    They do blow diodes in the control unit does the fan work
    May 2016
    311
    Yes, the fan blows and the heater works. Ac lights come on and the compressor kicks in but then airflow drops and some weird noises from under the dash happen..
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    353
    I don't really know how the Cooled side of the system regulates itself, so just throwing this idea out there.
    Faulty flap controlling air flow over the evaporator. Maybe a busted drive gear on the flap.
    1,573
    The cooling side is controlled by the thermostat which is connected to / controlled by the dial at front of dash, eg temperature.
    307 HDi wagon
    407 HDi wagon
    1000+ Posts silverexec's Avatar
    Melbourne, Victoria
    1,001
    Is there a climate control ECU managing the whole system like there is in the 405? I only finally discovered this elusive part hiding at the bottom of the A/C enclosure behind the centre console. Mine's a bit stuffed - no temperature regulation, only full hot or cold. Seems to be a common problem from my research.
    - Richard
    Now: 405 SRI D70 '93
    - 2.0L manual
    Earlier: 505 GTi Executive '85
    - hence "Silver Exec"...
    25 GTX '86
    - manual conversion
    1,573
    405 maybe. its like the 205, just a closed loop system that just turns off and on with some hysteresis. Unless its got some smarts which most likely came with the variable compressors in later models like the 306, its a lot smarter / more complicated.
    307 HDi wagon
    407 HDi wagon
    May 2016
    311
    As far as I know there is an ecu controller. It's linked to the interior temp sensor in the roof and theoretically keeps the interior at the set temp. The car in question is a 2001 xsi so is the last of the 306 years.
    May 2016
    311
    I'm getting the impression that if the big mechanical parts are fine then I'd better get familiar with a multimeter!
    1,573
    Give me a few weeks and I will have one (306, 2002 model) as well. To investigate but to complicate things its a convertible so no sensor in the non existent roof.
    307 HDi wagon
    407 HDi wagon
    6,046
    Shane (Double Chevron) and Robmac are pretty good generically with a/c but prob not specifically with the 306.
    2003 PEUGEOT 206 GTi
    May 2016
    311
    Hmm, good to know. By the way, I don't have this car yet, but have looked at it. A very nice China blue xsi... With near perfect paint! Only real downside is the 250,000 Kay's and no ac!
    May 2011
    melborne
    353
    Quote Originally Posted by Matthew View Post
    2001 306's have the variable output compressors and has a more advanced control system, as in it don't switch the cold on and off to regulate temperature, but actually varies the compressor output.
    Given that the system works otherwise, and that the air flow is physical cut off accompanied with noises when cold air is requested, would suggest that the computer is working fine, but something mechanical in the vent system has failed.
    I've never had one apart, so I'm not familiar with how the cold air is mechanical regulated, but there is a flap in the evaporator box referred to as AIR CONDITIONER REDUCTION. This would be my bet as to the cause. The drive motor that controls it looks to be located on the bottom right side of the evaporator box. Not sure how easily accessible it is.
    lowpugV2 likes this.
    1,573
    The penny drops, these dash boards have electric motors to drive the flaps, the noises you hear are those motors. They are not working so no air gets to you. I have a dash and airbox out of a 306 and if you were here would show you. As mentioned above they are held in with screws and can be removed / replaces. Good luck.
    If required I can get a picture of this location for you.
    307 HDi wagon
    407 HDi wagon
    May 2016
    311
    Quote Originally Posted by gromzx View Post
    Genius, I reckon that's it. Thanks!
    May 2016
    311
    If you could ( as long as no hassle) I would appreciate it. If I get this car fixing the ac would make it a rare beast.
    1,573
    Of course, home late and its dark, might have to wait until weekend? How desperate / in a hurry are you?
    307 HDi wagon
    407 HDi wagon
    Preston, Melbourne
    254
    I'd go with the heater flap thesis. Either the gears of the flap shaft itself. Mine is broken all along the shaft. Put the endoscope down to see what was wrong, but haven't motivated myself to take our the dash yet.
    Sent from my LG-H815 using Tapatalk
    06 Citroen C5 Estate 2.2 Hdi Auto
    95 Peugeot 306 S16
    95 Silver Xantia VSX - now deceased
    May 2016
    311
    No hurry, whenever suits. Haven't decided on the car yet. Thanks!
    Jun 2004
    137
    Just to add another a/c diagnosis. Borrowed daughter's 206 and tried to diagnose an ineffective a/c. Eventually (to make a long story short) found to be the a/c on/off button on the dash. It turned on (very dim light indicator) and would randomly turn itself off after a few minutes. In the bright light of summer, didn't even pick this event occurring. Naturally the problem was intermittent. Problem solved by getting another 206 dash console from the wrecker.
    1,573
    Here it is, not too hard but up a little in front and too the right of the blower fan under the
    dash.
    From on top, you will not see this but it shows both flaps controlled by motor
    306 air conditioning/climate control-imag1256.jpg
    From in front, motor is the grey / silver thing held in by a few screws.
    306 air conditioning/climate control-imag1255.jpg
    Easy decision really, its fixable and if the price is right?
    307 HDi wagon
    407 HDi wagon
    May 2016
    311
    dash.
    Cool, thanks for those pics. Currently experiencing a car confusion right now... seller of the 306 says there's someone coming tomorrow to see it, eek! I've also gone and got interested in a xantia! I wan't a big garage...
    1,573
    Pug is eaier / more common, cheaper to maintain, far more important.
    307 HDi wagon
    407 HDi wagon
    May 2016
    311
    So, this is coming home with me tonight. Taken a gamble, stuck with the pug for now. I'm just crossing fingers I can sort the AC with minimal cost - maybe just some skinned knuckles!
    Matt, I'll be asking questions!
    306 air conditioning/climate control-img_20180416_112705.jpg
    leithant and silverexec like this.
    1,573
    No trouble, nice choice good looking car. Love fixing things! It did occur to me that it might be the shaft the things runs on, less likely than dodgy motor but possible all the same, this might mean dash out to fix!
    Lucky I have a spare box to play with / refit for a stuffed one. Where is my convertible, I want it?
    307 HDi wagon
    407 HDi wagon
