A couple of weeks ago the starter solenoid would only click but 20 minutes or so later it stirred over like normal. At this point the trip computer disappeared. It can be viewed briefly if the end of the stalk is pressed but is reduced in size on the screen and disappears again shortly after the button is released. It started fine for a week but then failed again and the battery voltage was dropping 12.4 to 10V under load from the starter (well, only the solenoid). Jump started it and there was 14.4V so replaced the battery. Fine since but still no trip computer. Any suggestions?
Thanks,
Hugh.
