205 heads
Results 1 to 21 of 21
  • 1 Post By cam85
Thread: 205 heads
    Mar 2005
    316
    Default 205 heads
    Hi all,
    Looking to get a head “built” for my 205SI so that I can swap heads over on a weekend and not have the car off the road too long. It currently has leaky valve stem seals.
    This means sourcing a second head to have machined etc.
    Can I use a head off a GTI or must it be an SI head?
    1000+ Posts cam85's Avatar
    Nov 2003
    Bondi
    3,268
    Apparently the can be replaced in situ?
    Cam
    amcc likes this.
    Nov 2003
    Bondi
    3,268
    Cam
    1000+ Posts Dave's Avatar
    Apr 2001
    1,340
    Mar 2005
    316
    After reading that, now I’m even more set on finding a second head!
    7,371
    The heads themselves are physically identical. I have seen differences in valve springs however, meaning a GTi cam could make Si springs go solid. Thus if you bought an Si head as a replacement for your GTi, with the intention of swapping it over, I'd be very careful.
    Mar 2005
    316
    I'm assuming a GTi cam + springs... complete head assembly wouldn't give the single point injection too much drama.
    Oct 2002
    16
    I just compared a GTI head with a SI head and can't see any difference except that the GTI cam had a higher lift. I had two bent valves so I used 2 valves from a high mileage SI head. They fitted perfectly, lapped in, in 2 minutes and the cam follower clearances were exactly the same. You can have my SI head, all springs are gone but it has 3 of each valves, exhaust & inlet.
    Oct 2017
    Yandoit, Victoria
    19
    I have Aprila's old 205 Si with a GTi head and cam and it has less power than it could because it doesnt have the ECU to match from the GTi. Aprila said that if I change over to a GTi ECU it'd outrun the old setup with ease. That was his plan. Currently however I do not have the ECU so it's a little gutless.
    Not sure if this helps at all.
    Mar 2005
    316
    Will a timing belt kit for a 1.9 GTi work with an SI or will it end in bent valve sadness? Hard to order Gates stuff for an SI because the UK never got SI's, even calling Halfords isn't sure about it because it's not on their computer.
    Cheers for the offer 404Phil, but i've resigned to the fact the car will be off the road for a week or so while the heads off!
    Oct 2002
    16
    Timing belt should be the same between SI & GTI, so long as the tensioner is similar. I'm not sure if the belts are similar between early & late tensioners. I thought there is a one tooth difference???
    1000+ Posts driven's Avatar
    Apr 2005
    1,312
    Always take care when working / changing / setting valve springs.
    As good as many
    How to Properly Handle Valve Springs
    8,974
    Sis came with both the early and late tensioners, if it has the eccentric, not spring loaded tensioner it will have the late belt, 114 teeth, one more than the early one.
    Quote Originally Posted by 404phil View Post
    Mar 2005
    316
    Got it all off, seems I have the early type.
    Chipped the crank pully levering it off because i'm an idiot... replace it or run with it?
    1000+ Posts CEyssens's Avatar
    Jan 2016
    Berwick VIC AUS
    1,032
    Quote Originally Posted by Selekta View Post
    How big is the damage? Got a photo?
    Mar 2005
    316
    8,555
    That'll be okay. Mine had a lot more damage than that when I got the car. I would however make sure there's no sharp edges that could damage the belt.
    Very very fragile casting, that. I got a couple of perfect spares now, but I guess if you could lay hands on a machined Aluminium one it would save a lot of trouble in the future. I would like to machine one for myself but I don't have a broach or a shaper to cut the key slot and some 7075 stock in that size is not cheap to get. Most places in Oz don't even have 7075, I had to import some from amerikia where I found the best price/delivery cost deal.
    ACHTUNG ALLES LOOKENPEEPERS
    Mar 2005
    316
    Yeah, that damage was just from trying to use a bearing puller on it... not actually pulling, but trying to slide the prongs in behind it.
    7,371
    doesn't need to be 7075 Shulzwagen, just needs to be anodized. If you're not running A/C, you can use a single from a lesser model. They're no where near as fragile.
    8,555
    I pulled one off nicely and gently with the engine in situ and then it just dropped out of my hand so it must have been what? 10-20 cm off the ground? Chipped just like yours. Bloody french cast steel de merde!
    You don't need a puller to take it off. Just put loads of WD40 on the shaft, and wobble it gently by hand. It does eventually break the gunk and slides off. Be careful, the timing belt sprocket is just as delicate and I bet the camshaft one is no different. I would not use any tools/force on any of them.
    Mar 2005
    316
    Mmm, a quick tap with a rubber mallet (on the centre) did the trick in the end.
    Question number 10 million: heads off, lots of debris fell into the void. I’m assuming once the head is back on a blast of fresh water through the motor will clean all that out?
