405 front end noise
    Yamba NSW
    65
    Default 405 front end noise
    Today I drove over a very corigated dirt road to get to a surfing spot. Mt car has developed a very loud knocking sound which was very much more evident on this road.It sounds like the knocking sound when a shockie rubber has gone when I got home I checked to see if there was evident loose bits withuot luck so before I take it to a mechanic which I would prefere not to any ideas from you knowing Peugeot people. Cheers LuLu
    1000+ Posts Warwick's Avatar
    Nov 2002
    2,664
    I believe this is just standard worn 405 strut noise. Of course something else could be wrong as well.
    Yamba NSW
    65
    Quote Originally Posted by Warwick
    Thanks Warwick any ideas how I can check the strut I am not even sure which area of the front suspension to look.Would it be a difficult job to replace? LuLu
    Moderator Alan S's Avatar
    Queensland, Australia
    8,923
    Drop links on the sway bar by any chance??
    Alan S
    12,266
    take it to a suspension place and get them to give it a check over
    they normally only charge around $15-30
    and they check everything very well and give you a report
    much better than one of us trying to diagnose it when there are so many things under there that can cause the noise
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
