Pug 2.2 Diesel engine mounts
Results 1 to 8 of 8
  • 1 Post By thatguy
Thread: Pug 2.2 Diesel engine mounts
    Apr 2012
    41
    Default Pug 2.2 Diesel engine mounts
    Has anybody had experience with mount replacement to rectify harsh engine vibration on the 2.2 Diesel engine?
    So far Iíve had a top mount and a gearbox mount replaced (which improved things a little) but still looking for vibration source.
    Glenn
    Member thatguy's Avatar
    Oct 2012
    100
    Experiencing the same so keen to learn other's progress.
    Have harsh vibration, worst when at lights with with brakes applied. Still there when in neutral but definitely less.
    Had the engine dampener replaced at last service but this delivered little (if any) improvement. Much forum and internet searching suggests others experiencing the same but no definitive solution - references of everything from internal engine balancing to loose bolts.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,330
    Is the harmonic balancer in good condition, is the rubber still bonded to the inner and outer rings, is it running true?
    Worth a check.
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Oct 2012
    100
    As housekeeping found the cause of vibration was a faulty active damper. New unit installed and now things back to normal
    BIGRR likes this.
    tweed heads
    1,402
    Also if the rubbers that secure the engine cover are shot ,the cover rattles at idle,if you hold it down with your hand noise reduced a lot .pugs
    Sep 2003
    North Parramatta
    3,955
    Quote Originally Posted by thatguy View Post
    Do you have another description of an "active damper"?
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    927
    An engine mount that works like a active shock with variable valving if that makes sense
    5,933
    Engine Suspension Control System
    2003 PEUGEOT 206 GTi
