Peugeot 207 gti auxiliary driver belt replacement
Results 1 to 7 of 7
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Default Peugeot 207 gti auxiliary driver belt replacement
    Hi,
    Just would like to ask on how would I be able to replace the auxiliary driver belt for Peugeot 207 gti?
    Please help I bought the auxiliary belt from supercheap auto I just need to put it on.
    Thank you.
    8,067
    Two tricks on the EP6 engines:
    1. Rotate the tensioner clockwise until the notch aligns with the pin. There is a retaining pin
    2. The coolant pump drive wheel has a hard to spot release tab on the upper section near the belt. Pull.
    Put the belt on starting with the crank pulley. Re-engage the pump tab, then retension the tensioner.
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Peugeot 207 gti auxiliary driver belt replacement-img_1518240042.151755.jpg side view of the engine
    Which tensioner needs to go clock wise??
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Can you please show me in the diagram n mark it. Thank you seasink
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    All good seasink I get it now. Thank you.
    8,067
    Peugeot 207 gti auxiliary driver belt replacement-drive-wheel.jpgPeugeot 207 gti auxiliary driver belt replacement-tensioner.jpg
    AAA
    AAA is offline
    Member AAA's Avatar
    Nov 2016
    Australia
    67
    Thank you seasink big help.
