308 T9 Temperature
Results 1 to 15 of 15
    Sep 2016
    Denmark, WA, Western Australia
    67
    Default 308 T9 Temperature
    Hi all,
    My Pug 308 T9 has come up with engine overheating fault on display and needle goes to the red after 2 or 3k of driving. Car has plenty of coolant and oil level is fine. Anyone else hasd this come up on their 308?
    Sent from my SM-G950F using aussiefrogs mobile app
    Sep 2003
    North Parramatta
    3,955
    The 1.6 petrol motors (not sure what yours is) have a bit of a history of the coolant temp sensor failing.
    It’s on the thermostat housing and some earlier versions were not individually replaceable (ie. you had to replace the whole housing, which is not cheap) but later versions repositioned the sensor and it was individually replaceable.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Sep 2016
    67
    Its a 2014 2.0 blue hdi. Is it safe to keep driving with the error message then? I am 300kms from home and need to drive.
    Sep 2016
    67
    Just had the ECU read by a mechanic and the thermostat is electronic and keeps sending the temp needle to high even though the car is not hot. Had the errors cleared but it just came on again after 100kms driven.
    Sep 2016
    67
    Clearly an intermittent issue as the error message has now disappeared for now. How I hate intermittent faults. Any advice welcome as the original error message bothers me.
    Fellow Frogger! Doush_504's Avatar
    Cairo, Egypt
    613
    Very strange as it's an error related to the 1.6 petrol engines.
    They had a recall campaign to install a 2nd temp sensor in the thermostat housing for the cars that came with a single sensor housing along with the necessary harness.
    Chadi
    1982 504 SR white manual sedan with A/C (257 000 Km)
    2012 308 1.6 VTi Vapor Grey manual H/B (35000 Km)
    1994 405 1.6 white manual sedan (208 000 Km)
    1992 605 SV24 (91 000 Km)
    2005 406 2.0L automatic (Replaced with a 2013 C5)
    1983 505 GR white manual sedan with A/C (170000 Km)
    All since new
    Sep 2016
    67
    I managed to plug in a OBD and get the ECU to report error P2683: Engine Coolant Bypass Valve Control Circuit High. If anyone has any idea what this error relates to, and more importantly, a fix, I would be most grateful.
    May 2015
    69
    Not sure if it is relevant but I had a similar problem with a 405 SRDT showing the temp gauge running very hot intermittently with the fan cutting in.
    Spent lots of $$$$ at a Peugeot dealer who tested the system and then said the sensor had failed. But the problem reoccured.
    Took it to a Peugeot specialist in Brisbane who told me to pop the bonnet, he jiggled a connection, permanently solved the problem and sent me on my way. Must have been there for all of 60secs.
    Sep 2016
    67
    Thanks BlindFreddie. The error message has not returned and their are still no symptoms of overheating but P2683 is still logged in the ECU. I am ignoring it for now. Plugged the OBD into my wifes Pug 308 T7 and she has a whole list of logged errors in her 10 year old car without any symptoms of a problem. Maybe the ECU's in cars throw thinhs up all the time?
    May 2015
    69
    "Maybe the ECU's in cars throw things up all the time?"
    Suspect that has happened once or twice in my 308 T9 but not sure if it was an error, an error attended to but not cleared or the cause of the error was simply ignored and cleared by the dealer.
    No wonder my old Peugeot specialist said to me the 405 was the last decent Peugeot made (before the current 308 T9). When asked why he said because it had no computers.I suggest you find yourself a local Peugeot specialist you can rely onjust to make sure there is nothing untoward.
    Fellow Frogger! dmccurtayne's Avatar
    Jul 2013
    Newcastle/ central coast
    918
    Yeah ok 405s having no issues with computers lol bitron boxes mm ecus the late mi16 ecus with playing up map sensors all when close to new rose coloured glasses maybe
    May 2015
    69
    Guess I was just plain lucky! As were the many other 405 owners I met over the last 20 years and the 550,000km I had the car.
    Sorry and surprised to hear about your car. After purchasing a 405 SRDT a long and many time Peugeot owner and journalist told me he could now understand why the 405 had such a cult following.
    Jan 2014
    Coffs Harbour, NSW Australia
    252
    Re the 405 and computers, would there be a chance that a manual 406 D8 with Bosched 2.1 diesel may be, give or take central locking, actually be the last good ole electronics hassle free Pug. Mine's only got about 420,000 on it, but the idea of renewing it a bit is appealing and if the Poms are right that it's not hard to get them to give 160 HP the 'old girl' could be a fine mode of transport for a decade or 2 more.
    All the best to y'all; cheers.
    Jul 2013
    918
    Agree the 2.1s were good but the v6s wow we did heaps of engine ecus but also blindfredie yes the diesels were great I specifically mentioned mi16s could be worse could be a holden Iíve never seen so many
    Sep 2016
    67
    This safety recall has just been done on my Pug so fingers crossed.
    https://www.productsafety.gov.au/rec...geot-p308-t9-0
