Engine is hunting.
Like Tree2Likes
  • 1 Post By gromzx
  • 1 Post By The Fixer
Thread: Engine is hunting.
    Jun 2012
    Port Macquarie
    40
    Default Engine is hunting.
    2005 407 HDi 2.0
    When driving up a slight hill the engine began to hunt and my speed started to taper off and it felt like the engine was about to stall, as I only had 50mt to go I drove home. When I checked the coolant expansion tank it was just over maximum, temperature gauge showed 95 degrees and the radiator fan kept going long after the engine was off. I let the engine cool and drove up some ramps, put a header bottle on expansion tank and bled the system, did not appear to be any air in the system so as per manual started the engine and reved up to just under 2000 rpm, then the engine started to hunt I backed the revs but even at idle the engine is still hunting.
    And the radiator fan did not kick-in at around 90 odd degrees.
    I should also say that the turbo had not been kicking in during that drive. I have removed every vacuum tube/pipe and no leeks to be found, (with a vacuum pump). Could the fact that the turbo is not working have caused the overheating and lose of power or was it due to the fan not working (it does if the A/C is on).
    8,953
    RHR in the VIN? Read this thread:
    C5 power down
    Check your turbo air piping for splits and the vacuum system for leakage, paying attention to the y-piece down the front. If anything is broken and leaking, the turbo boost will be low. The car may add more fuel to compensate and may run hotter as a result.
    Otherwise, a bad EGR valve can cause hunting. They can drop the valve head or the weld on the control arm can fracture.
    Fellow Frogger! gromzx's Avatar
    May 2011
    melborne
    346
    Try disconnecting both the vacuum lines from the Y piece and plugging them and see if the hunting stops. This is an indicator that the egr valve has failed.
    Dano likes this.
    Jun 2012
    Port Macquarie
    40
    I have just replaced the EGR with a new one last week, and my turbo is still not working and I have check all tubes with vacuum pump no leaks I have also check the turbo itself appears to be OK. I'll do some more checks, see what I come up with.
    Thanks for your advice.
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,294
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    Jun 2012
    Port Macquarie
    40
    Cheers David S you were right there was a split in the turbo air pipe (vacuum system , no leaks) I have just relaced the turbo air pipe and now have turbo boost.
    One thing remains, engine appears to misfire, when driving at any speed, more noticeable when decelerating, so suppose it might not be a misfire. I am at a lose as to what is causing it. Maybe another smaller split in a pipe somewhere don't know!!! Any ideas????
    Dano likes this.
