Engine cover removal - 207 gti
Results 1 to 10 of 10
Like Tree2Likes
  • 1 Post By seasink
  • 1 Post By seasink
Thread: Engine cover removal - 207 gti
    Jun 2017
    WA
    16
    Default Engine cover removal - 207 gti
    Hi all,
    I am wanting to have a look under the engine cover (in the attached pic, the cover with the Peugeot logo on it - ignore the red arrow).
    Is this easy to remove...I can't seem to see a 'trick' or fasteners that need undoing?
    Sorry for the really newb question...
    Attached Thumbnails Attached Thumbnails Engine cover removal - 207 gti-gtiplug.jpg
    1000+ Posts gezza's Avatar
    Bunbury
    2,089
    The silver bit is held on with two pin like clips in the centre, the rocker cover/valve cover is the ten mm bolts allthevway around. The square housing is sealed don5 pull it off like i did on mine to attach a catch can hose on the outlet to the left it breaks the seal in the underneath were you cant see. You will have oil pouring out everywere when ypu drive as you gotta get gasket seal yo reseal. Hope that makes sense.....
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
    7,034
    Don't even try. It is the oil separator, and is integral with the full head cover. Underneath it looks like this-
    Engine cover removal - 207 gti-couvre-culasse.jpgEngine cover removal - 207 gti-culasse.jpg
    Attachment 102463
    7,034
    Since you are curious, it works like this -
    Pressurised oil and coolant passages are in red and blue;
    Rising blow-by is in the green ducts;
    Falling oil, from the separator and the camshafts is orange.
    The interior of the separator looks like this Engine cover removal - 207 gti-deshuileur.jpg
    737
    Just for completeness sake, is there a seal or gasket to worry about on re-fitting, or does it use a liquid sealant?
    206 GTi 180 - Cat Cams, Remapped Group N ECU, AST Camber Tops & Coilovers, -2deg fixed camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Yokohama A050, PeugeotSport Baffled Sump, Powerflex Engine Mounts & Bushings, Setrab Oil cooler, Quaife diff, Velo seats.
    Sandown - 1:31.5
    Winton - 1:45.6
    Phillip Island - 1:58.4
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    7,034
    speaksgeek likes this.
    Jun 2017
    WA
    16
    You guys are champs - thanks for all the info.
    The reason I asked is I seem to be getting a very small amount of oil 'weep' appearing around the spark plug holes to the right (the right-most hole has the most, and it seems to be making its way to the left).
    It really only started after I fitted the induction, so my first thought was the pcv pipe that runs to the air intake might not be sealing properly (it does come off rather easily), and as the pipe now sort of goes up and then down to the intake, any oil in this pipe runs back down to the pcv, but now can 'sneak' between the pipe and the pcv outlet and onto the cover (does this make sense?).
    Is this feasible? If so, would a new pipe fix it (I will put new pipes on when I put on the catch can)?
    Could there be some other reason?
    Thanks again.
    7,034
    The induction doesn't carry vapour from the inlet until just before the turbo, and it drains to the turbo. The pic shows the seal around the spark plug hole. Perhaps there is now pressure from blow by helping some seepage.
    The standard THP engine has no obstruction to incoming air, it's rather noisy as a result, with a very large air filter.
    Bunbury
    2,089
    Heres mine jst about finished
    Attached Thumbnails Attached Thumbnails Engine cover removal - 207 gti-28ef693d-5f9d-4465-b79d-7e66c4155354.jpg
    7,034
    Engine cover removal - 207 gti-ds3-r1.jpg Save some bother - the DS3-R1
    I'd have stayed with a road car.
    gezza likes this.
