505 GTi manual clutch
Results 1 to 11 of 11
  • 1 Post By GRAHAM WALLIS
Thread: 505 GTi manual clutch
    83
    Icon11 505 GTi manual clutch
    Driving through Shepparton today and "lost" the clutch. It just went to the floor.... Very light - I could sort of change gears, but very carefully. It has developed a late take-up over the last 3 weeks, but nothing like this. It came progressively (reasonably) good after another 150km - still not right, but could change gears.
    Checked fluid and reservoir half full as normal. No obvious signs of leaking at slave or master cylinder.
    any suggestions please?
    cheers,
    Glenn and Tim
    SWOTR
    2,965
    Assuming hydraulics are okay - a broken clutch fork?
    Hobart
    1,450
    It could also be the pushrod from the pedal to the master that has sheered through. I've had a couple go on me now!
    Ben
    1988 Peugeot 505 GTI Wagon
    1994 Peugeot 405 Mi16
    1995 Peugeot 405 SRDT - Retired
    1973 Peugeot 504 GL
    1985 Peugeot 505 SRDT
    1000+ Posts BIGRR's Avatar
    Feb 2006
    North Rocks, Sydney
    2,159
    The clutch slave cylinder and the end of the clutch fork are easily sighted under the car. They are attached where the gearbox attaches to the engine. Have someone operate the clutch pedal and see what moves under the car. If the cylinder rod does not move it is probably the cylinder seals that need replacing
    Present fleet:-
    Peugeot 93' 205 Gti 16v
    Peugeot 73' 504 Ti from new
    Previous fleet:-
    Peugeot 95' 605 Sv
    Peugeot 92' 205 Gti
    Renault 72' 16TS from new
    Renault 69' 10
    Renault 71' 10s
    Renault 68' 10 from new
    "Be reasonable do it my way!"
    8,306
    Could be the master or slave cylinder cup if it came good again.
    BIGRR likes this.
    Fellow Frogger! luthier's Avatar
    Northern NSW
    907
    Could also be the fibre inserts getting ready to evacuate. I had a clutch on a Toyota do this, give a big sign when it refused to change into any gear, then finally it did.
    Later I almost got home, less than a hundred yards when it failed completely leaving the engine spinning but no transfer of power.
    When removed the fibre had all been stripped out of the clutchplate.
    So if you don't find fault with the master or the slave I'd say pull it out for a looksee.
    83
    thanks for all the thoughts. we'll have a look today....
    cheers, Glenn and Tim
    Member SamT's Avatar
    Dec 2012
    Kyneton, Victoria
    82
    Default 505 GTi manual clutch
    I've had a broken clutch fork on my 505. Was replaced when I did the clutch then broke with same symptoms you mention, although very quickly on one 100km journey home. Good luck
    83
    Thanks to you all for the advice.
    It was a combination of a leaking slave cylinder (but we hadn't lost much fluid, so the seal can't have gone completely...) and a worn pedal push rod.
    cheers
    Glenn and Tim
    SWOTR
    2,965
    Another problem solved and with a minimal repair cost!
    1000+ Posts Beano's Avatar
    2,411
    When you get that push rod welded up, you'll be amazed at the feel of the pedal...like new.
