208 wont go after faulty jump start
Results 1 to 3 of 3
    Jan 2018
    perth
    1
    Default 208 wont go after faulty jump start
    hi . we have a 208 Alure . It was given a reverse current jump start
    We have had a scanner put on it
    the scanner cannot read the engine ecu but can read the other systems
    the dealer thinks it needs a new ecu but is not sure , also thinks the fuse box is damaged somehow.
    we have had the ecu checked internally by a electronics expert and they think it is ok
    Also the fuse box appears ok and none of the fuses are blown.
    has anyone had a similar experience after a faulty jump start .
    is there a hidden fuse that we may be missing
    Aug 2016
    Sunshine Coast, QLD
    595
    Oops...you're not the 1st and wont be the last. I have noticed the BSI which is the fuse box behind the glove box on most of the Cit & Pugs have been damaged by the reverse current.
    I have repaired the older 2002 -2004 versions and at the moment investigating a 2008 model Pug to see if same repairs can be made.
    PM me your vehicle details as I may be able to repair and save having to buy a replacement and have a dealer reprogram the cars ECUs again.
    Oct 2014
    Brisbane/Australia
    335
    have a chat to dimistyle.
