207 GTI - what does this 'sensor' do?
Results 1 to 14 of 14
Like Tree5Likes
  • 1 Post By stew
  • 1 Post By vegie
  • 2 Post By seasink
  • 1 Post By gezza
Thread: 207 GTI - what does this 'sensor' do?
    Jun 2017
    WA
    22
    Default 207 GTI - what does this 'sensor' do?
    Hi,
    Can anyone tell me exactly what the plug (or sensor) that the red arrow is pointing to actually does?
    In order to put on an induction kit, this plug is effectively unplugged and not re-plugged in. Are there any detrimental effects to doing this?
    Will it throw CEL's or other errors?
    I am guessing it is an air meter of some sort, so will my fuel economy suddenly turn to crap, or is there something else that may happen?
    Thanks in advance.
    Fellow Frogger! stew's Avatar
    Apr 2011
    brisbane
    465
    It is an crankcase breather gas, temperature sensor.
    Jun 2017
    WA
    22
    Thanks for that info.
    What are the effects of leaving it unplugged (if any)?
    1000+ Posts gezza's Avatar
    Bunbury
    2,167
    No effects don worry about it.
    1990 Renault 5 GT turbo
    ####current rides####
    1994 205 gti 1.9 sorento green
    1988 205 gti 1.9 uk import grey
    2001 clio 172 sport ph1 #44/85
    1998 306 gti6. Blaze yellow
    1992 Honda Fireblade
    2013 Yamaha fzs sho Jetski
    1998 Supra RZ twin turbo white
    1999 Wrx classic gc8 sonic blue
    Apr 2011
    brisbane
    465
    It helps to trim engine performance if the temp increases enough for the oil vapour to be hot enough to cause pre ignition when it finds it's way past the inlet valves. For some unknown reason leaving it disconnected doesn't seem to bring the check engine light on. One of my theories with that engine is the air filter is so good it starts to cause a low pressure at the breather outlet making a nice vacuum to pull oil vapour into the inlet. Hence the sensor to help trim the engine induction enough to allow for this. I've found the modern air filters air very good but also very small in surface area so they need changing almost every oil change. Just my thoughts. Of course a breather can system would be a much nicer way to go.
    vegie likes this.
    Jun 2017
    WA
    22
    Thanks for your replies. I have bitten the bullet and installed the forge induction - which was much easier than I thought.
    I didn't notice any difference after (not that I expected to), except for one. Under 'hard acceleration', when changing gears, there is now a very audible 'whoosh' whereas before there was no sound. I have a GFB diverter installed also,
    I am actually not sure whether I like it or not.....time will tell.
    Next is a catch can I think..
    gezza likes this.
    Apr 2011
    brisbane
    465
    Yeah, catch can is a fine idea.
    Bunbury
    2,167
    Cacth can and pcv delete, besides my exhaust you will have dimiliar mods to me then ��
    Jun 2017
    WA
    22
    Quote Originally Posted by gezza View Post
    I am a little confused with this. With a pcv delete, why would you need a catch can? I thought the catch can caught the oil residue from the pcv and prevented (some/most of) it from going into the intake?
    7,785
    There are two visible outlets from the built-in oil separator. One leads to the front of the turbo, the other to the intake manifold plenum. The separator has valves so that flow is directed to low pressure. Catch cans if fitted intercept vapour in these lines that got past the separator. The most common one used is on the line to the manifold.
    Most crankcase oil drains from the separator down channels cast onto the back wall of the head and block.
    gezza and vegie like this.
    Bunbury
    2,167
    Pcv delete blank caps 1 goes to the back of the head on the left and the other to at the back on the inlet msnifold.
    Your oil catch can goes from the head on the right and up from your induction kit.
    i was doing this mod way before e tuners put it on there website!! Layer 207/208 gtis have the pcv delete but no catch can.
    vegie likes this.
    Jun 2017
    WA
    22
    Thanks seasink and gezza.
    Would you put a catch can on both? I have read some conflicting stories about the pcv delete mod around crankcase pressure and oil leaks and oil usage after the pcv delete has been done.
    Can you still get the blanking caps?
    7,785
    Most systems intercept the manifold line. Some do both. The problem is finding room under the bonnet to put the cans. Forge is well known but you may be interested in this approach used mainly on large engines - https://www.mann-hummel.com/fileadmi...nt_en_2013.pdf
    Sep 2003
    North Parramatta
    3,922
    Quote Originally Posted by vegie View Post
    They are there.
    Its not a simple “PCV delete” that PSA have done, despite the blanking caps. The rocker cover-based PCV system has been redesigned a few times.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
