86 505 GTD Turbo Brake Pump Problem
Results 1 to 7 of 7
  • 1 Post By pugwash
Thread: 86 505 GTD Turbo Brake Pump Problem
    TEC
    TEC is offline
    Jun 2015
    Tasmania
    14
    Default 86 505 GTD Turbo Brake Pump Problem
    Trying to help another Frogger out with a hard brake pedal problem. I connected a vacuum gauge to the brake pump. The vacuum reading on the gauge reads almost zero at idle and at revs. Suspect the pump is shot. It is a sealed unit belt driven type. I am unable to find a replacement local. Anyone know what is available. Thanks in advance.
    Avisford NSW
    508
    Post in parts for sale and wanted
    tweed heads
    1,366
    Just did a search on e bay ,alternator/vacuum pump,i recall the mitsubishi l300 diesel i had ,had the vac pump attached to the rear of the alternator ,i see toyota and nissan ,do the same thing ,if you are not too precious about originality ,and the alternators are compatible it may be a quick fix ,with the bonus of a new alternator to boot ,pugs ps most seem to run v belts
    Wildebeest likes this.
    Aug 2017
    Perth
    5
    I have a new un-used brake vacuum pump purchased when I mis-diagnosed a brake problem on my 505srd Turbo. Not cheap, but will sell for a heavy discount on new cost.
    TEC
    TEC is offline
    Jun 2015
    Tasmania
    14
    Thanks Andrew, I will pass that on. Latest was the owner was checking if an electric pump can be installed.
    Apr 2005
    Gundaroo
    121
    Quote Originally Posted by TEC View Post
    I had a crook vacuum pump on my 504 ute that has an XD2S engine. I could not find a replacement vacuum pump new or second hand at the time and I needed a replacement quickly. I fitted an electric pump I purchased from Hoppers Stoppers (from memory) for a cost of about $500 approx. Works well - electric pump is a good replacement IMHO.
    Aug 2017
    Perth
    5
    The new (never used)
    pump which I have cost around $440 a few months back but as I do not need it I would accept under $300
