Incorrectly connected battery - Now no crank, no start - 2007 407 2L HDI - Page 2
Page 2 of 4 First 1234 Last
Results 26 to 50 of 76
Like Tree24Likes
Thread: Incorrectly connected battery - Now no crank, no start - 2007 407 2L HDI
  1. #26
    Oct 2014
    Brisbane/Australia
    361
    The BSI repair on our 407 was unsuccessful. So still unable to start my (new to me) wagon.
    I am now on the lookout for a used ECU, BSI and remote/transponder set from the same car. I have been advised to ensure the ecu part number is the same as what's in the car now. I have a Siemens VDO ECU - I think its part number is: 5WS40423C-T. See attached pic.
    Anyone know where I can find a 2007 pug 407 2.0 Hdi auto with this ECU and matching BSI, remote/transponder and optionally maybe even the instrument cluster?
    Incorrectly connected battery - Now no crank, no start - 2007 407 2L HDI-2018-01-12-15.19.24.jpg
  2. #27
    8,073
    Icon3
    Quote Originally Posted by dcc236 View Post
Name:	2018-01-12 15.19.24.jpg
    This one is close but no cigar, but could be worth contacting the seller. They claim to be able to supply as plug and play with your data transferred i.e. you send your ECU and they clone details to the replacement. Sellers contact details address and email at the bottom of listing.
    https://www.ebay.ie/itm/Peugeot-407-...item41d8ea3a2f
    If they have a problem dealing with Aus I have a London address you can use
    Matthew likes this.
    08 C5 X7 HDi very Noir
  3. #28
    Oct 2014
    Brisbane/Australia
    361
    The kids had a Hot100 party at the house while we are away in Sydney. One of the guys there was a mechanic and offered to have a look at the 407 sitting on stands on the nature strip out front of the house.
    He got the new battery I bought for it our the garage, installed it, and discovered my "no crank, no start" problem. He put his scanner on the car and found a couple of minor faults but nothing to worry about. However he did discover there was "no communication" to and from the auto gearbox and the gear lever will not move out of P.
    He suspects I have a faulty / blown gearbox ecu/controller. Once this is addressed, he reckons I can press forward to see if I have any other issues, like a damaged starter motor.
    This inspection was unplanned and done without my knowledge. Do you Pug experts think this guy might be on the right track? If so, Where do I find the ECU controller for the auto box in my car? Is it an item I can replace with one from a wrecker without the need for reprogramming or a dealer involved?
    I still can't believe I was silly enough to incorrectly connect my battery. Anyhow the car is a 2007 Pug 407 Wagon 2.0 Hdi auto.
  4. #29
    8,076
    AM6 box? The CAN connection is to the controller. Incorrectly connected battery - Now no crank, no start - 2007 407 2L HDI-am6.jpg The position switch is within the housing. The voltage read there indicates the gear stick position from P up to D
  5. #30
    1,503
    Instant friend and given he could do this with no prior knowledge hints at good skill / knowledge set. Worthwhile chasing it I would think.
    307 HDi wagon
    407 HDi wagon
  6. #31
    Oct 2014
    Brisbane/Australia
    361
    AM6 box? The CAN connection is to the controller. Click image for larger version.
ID:	103069 The position switch is within the housing. The voltage read there indicates the gear stick position from P up to D
    Thank you for that. Yes, AM6 auto. Is that controller/ecu able to be removed and replaced with a used one?
  7. #32
    Fellow Frogger! Roland's Avatar
    Perth
    709
    Incorrectly connected battery - Now no crank, no start - 2007 407 2L HDI-am6gbox.jpg
    This is the part for one of my 2007 2ltr Hdi Auto 307s.
    This is the same configuration engine/gearbox as for your 407 as far as I know.
    I checked my second 307 which has the same engine etc and is the same year (2007) and it has the exact same part numbers for the Electronic box.
    So, in theory you can swap them from car to car BUT notice that the part is numbered as 2529.W1 and is described as Part to be configured.
    And then the second part number 2529.AH says Configured part and vehicle ident no (VIN) to be specified on order.
    It appears that these are the same part but need to be programmed with the VIN of the car onto which they are to be used.
    Getting a spare from another car and plugging it in is probably worth a try but might not get you anywhere.
    Roland
    Land Rover Discovery 4
    406 Coupe D9 - Manual (2002)
    307 Hdi Estate - Auto - (2007)
    307 Hdi Sedan - Auto - (2007)
    505GR Estate - Personal Import from UK 1971cc Manual (March 1986)
    405 Mi16x4 (all the parts ready to install into the LeMans body)
  8. #33
    9,185
    Via DiagBox, it may be possible to temporarily configure the car to think it is manual for the purposes of a crank test. Then it would not be looking for the gearbox ECU. That is something to consider, but you'd need to be cautious about doing this.
    I don't think the gearbox ECU's are VIN coded, but the same physical part would run different software versions depending on the application and which engine it is hooked up to. There are compatibility requirements for engine and gearbox software, so it is not as simple as swapping them.
  9. #34
    Oct 2014
    Brisbane/Australia
    361
    I am quickly learning these cars are far from simple to repair and work on.
  10. #35
    8,284
    But simple and quick to completely root!!!
    COL likes this.
  11. #36
    Jul 2004
    799
    AM6 Ecu's can be swapped car to car- as David S says they are not vin coded.
    But realistically the above is just a guess. It could be stuck in park because its either in Economy Mode or there is no power to the Park lever solenoid/brake switch. However a faulty gbox ecu would cause a multiplexed vehicle not to start as it provides a gateway for the High Speed Can lines- but always start with the simple items first.
    With a vehicle in this state fault codes are usually not helpful and potentially misleading, because nothing is operating to log codes, car wasn't running when fault occurred and battery wasn't connected (albeit correctly) for any ecu to be operating at the time.
    Its not much help but you are going to have to start at the basics and have wiring diagrams to check for power in and out of components. Without a wiring diagram and a copy of diagbox/pp2000 you are just guessing.
    2006 Peugeot 206 Xt
    1991 Toyota mx83 grande 1jzgte
  12. #37
    Oct 2014
    Brisbane/Australia
    361
    Quote Originally Posted by James504 View Post
    Where do i get a wiring diagram from?
    If you are able to help me diagnose and fix this thing, pm me.
    My wife wants it off the nature strip. I don't even get back from Sydney until the end of the week, at the earliest.
  13. #38
    Perth
    709
    PM sent - did you receive?
    Roland
  14. #39
    Oct 2014
    Brisbane/Australia
    361
    Have found a BSM (engine bay fuse box) that I picked up cheaply, so i will try it when it arrives. Still struggling to find an auto transmission controller. Was quoted $1800 + labour from Brisbane Peugeot for one.
  15. #40
    Apr 2004
    Western Australia
    237
    There seems to be a few transmission controllers on Ebay starting at about $30 they may be worth a shot.
  16. #41
    Fellow Frogger! Ceenine's Avatar
    Devonport, Holiday Coast
    456
    I purchased one from a wrecker for $100 (albeit for an automated clutch C4 HDI 6 speed)
    2014 C5 2.2 HDI Limited Edition Sedan
    2007 C5 2.2 HDI Hatchback
    2007 C4 1.6 HDI EGS Sedan
    Peugeot Mi16 Series 2
  17. #42
    Oct 2014
    Brisbane/Australia
    361
    Quote Originally Posted by Ceenine View Post
    Have found two wreckers with the same part number as mine, one wanted $480 and the other $660.
    If I can't find one reasonably priced soon, I will wreck the car. Anyone looking for parts from a 2007 Pug 407 wagon 2.0 HDI 6 speed auto?
  18. #43
    Aug 2016
    Sunshine Coast, QLD
    772
    David check if the C5 Mk2 has the same TCU listed today
    C5 II Parts, Actia/Lexia, ECU Flasher, for sale, Hail took our ride away.
  19. #44
    Oct 2014
    Brisbane/Australia
    361
    Quote Originally Posted by dimistyle View Post
    You're a gem Dimi.
  20. #45
    Oct 2014
    Brisbane/Australia
    361
    I checked the TCU, ECU, BSM and BSI in my 2008 407 sedan this morning. It has all the same part numbers as the 2007 407 wagon I fried. So I decided to put the wagons TCU into the sedan and vice versa. The sedan starts but the wagon still doesn't. Lexia still doesn't talk to the TCU in the wagon that has the TCU out of the sedan (known good part).
    So what provides power to the TCU? Transmission Control Unit.
    Is there somewhere that will tell me what all the maxi fuses under the BSM in the engine bay are for?
    I also looked at the BSi's configuration in the wagon, most of the settings says "invalid selection". So I suspect it has lost its configuration/settings.
  21. #46
    SWOTR
    3,285
    One of things I take from your troubles is that I am surprised there isn't reversed polarity protection.
    neural revolt likes this.
  22. #47
    IWS
    IWS is offline
    1000+ Posts IWS's Avatar
    Feb 2005
    Hawthorn East, Vic.
    1,252
    Does this Peugeot 407 (2005) – fuse box diagram help? I know it is an earlier year - but I'd expect it not to change 2005 to 2008 (or maybe I'm wrong?)
    Ian.
  23. #48
    18,043
    Quote Originally Posted by Peter Chisholm View Post
    It's something I struggle to fathom too.
    Since nearly every electronic item has milli-cent diode in series with the supply line and is considered a engineering design necessity when accidental polarity reversal is possible.
    with apologies to Judy Grahn
  24. #49
    SWOTR
    3,285
    And it's not just a power transistor or whatever to replace, it's things here there and everywhere.
  25. #50
    Aug 2016
    Sunshine Coast, QLD
    772
    Can you re program the BSI?;I would think if you can change just one setting thru the configuration menu you might just need to manually change all settings like auto transmission?
