2003 206 gti
Thread: 2003 206 gti
    Nov 2017
    Milperra
    14
    Default 2003 206 gti
    Hey Frogs.
    greetings
    I'm Clarkey. I have just bought a 2003 206 gti.
    i have a few things to fix. The exhaust is hanging down so thats an obvious easy fix. There is a strange feel aboit the passenger suspension over bumps that feels like a loose top shock mount that i will need to replace.
    what are some other things i should check that this model is known for wearing out? 5 speed manual, 230,00 kms
    cheers mon ami!
    Jan 2017
    NZ Auckland papatoetoe
    59
    The clutch judders as mine did
    And then the release bearing fell apart.
    Then I changed it
    Sent from my GT-I9505 using aussiefrogs mobile app
    7,170
    My guess for the front suspension is a shot bearing. They sit in a cap at the top of the spring and its wet under there and the left side gets more bumps. When they go you get movement of the strut that gives a very noticeable knock inside the car.
    If so it's strut out. In the smaller PSA cars you will need to expand the hub at the back with a lever or tool as it grips the shock absorber. Spring compressors are essential.
    Nov 2017
    Milperra
    14
    Thanks for the responses. I bought a pair of 100,000 km struts better than mine and a complete exhaust from a guy wrecking one. They are going in tomorrow. My car is unregistered but i had a permit to bring it home. I have size 14 shoes which make the pedals a bit hard to cope with. I am impressed by the car however. It is quite nippy through the gears and well equipped for a 2003.
    i bought another one to fix and sell. It s a 206 CC with only 90,000 km with a gearbox problem.
    liberte, equalite, fraternite
