Peugeot 206 Horn and Reverse light both not working
Results 1 to 10 of 10
    Oct 2005
    Panorama Heights, Devonport, Tasmania
    115
    Default Peugeot 206 Horn and Reverse light both not working
    In a recently purchased 206, I have found that neither the horn nor the reverse light are working. I question whether or not it is for the same reason. I have checked all the fuses also globes in the reverse light and the horn and all work when tested ,but not in the car. Anyone had a similar experience ?
    1000+ Posts driven's Avatar
    Apr 2005
    1,217
    If purchase was recently, take back to Person who did Roadworthy as they are both items that need to work to pass the RWC
    If 206 has a horn relay, should hear a click when under the bonnet somewhere. Trace from there. Is the globe burnt out?
    Sep 2003
    North Parramatta
    3,933
    You could start simple.
    Obtain an assistant and carry out some "light" technical percussion on the horn while an assistant holds the horn button in.
    Remove the reverse light connector on the gearbox (should be on the front) and give it a clean out with some electrical cleaner.
    Simon
    2018 308 GTi 2011 DS3 DSport
    www.peugeotclub.asn.au
    Oct 2005
    115
    Thanks Simon: I was able to do this and after cleaning and reconnecting it worked. Wasn't sure about getting the electrical connection apart, but with a long handled screw-driver and prising at the bottom from inside to outside, it came apart.
    The horn still has me stumped !
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,629
    Don't need a RWC to sell a car in Tasmania. All the colonies ooops states in this country have different laws
    Regards Col
    1995 Renault Laguna V6
    2002 Renault Laguna V6
    1973 Alpine A110
    COL
    COL is online now
    A110 COL's Avatar
    Van Diemen's Land
    3,629
    Quote Originally Posted by PeterR View Post
    It could be just bad connections in the various plugs and sockets in the wiring looms, having a multimeter will help diagnosis.
    Regards Col
    1973 Alpine A110
    Oct 2005
    115
    Actually, with a lapsed registration, like mine, I had to have an AIS Inspection, hence my efforts to correct this fault.
    Oct 2005
    115
    Update on Progress:- After checking all the obvious, a good friend who is more into French cars than me,took the steering wheel off, checking under the airbag for voltage, then removed the unit which includes the traffic indicator, washer lever, lights etc. and carefully disassembled it. Two springs were slightly lengthened and contacts which are for the horn cleaned. When all put back together, the horn still did not work. The conclusion is that the computer is faulty and they are expensive. So, I am running a separate circuit from the horn with the intention of attactching a horn button . But. do you think I can find a pathway from the engine compartment ? Still working on that.
    Sep 2003
    North Parramatta
    3,933
    And the horn itself?
    Simon
    Oct 2005
    115
    You are right ! But not the horn, rather the plug that attaches to it. After trying another unit whichh includes the "clock spring" (for the want of a better word). No go. So on a much closer examination, I found that one wire that should have been attached to the plug was broken. It was quite difficult to see and to work on, but the moral of the story is to check the voltage at the plug, even if the horn is working with a separate test, before being suspicious of the more complicated parts.
