207 Outdoor clutch gone at 60,000km
Results 1 to 18 of 18
Like Tree4Likes
  • 1 Post By Beano
  • 2 Post By pinnaroo
  • 1 Post By SLC206
Thread: 207 Outdoor clutch gone at 60,000km
    Nov 2017
    4
    Default 207 Outdoor clutch gone at 60,000km
    Hi,
    The clutch has just gone on my 207 Outdoor and it's only done 60,000kms. The pedal just stays on the floor when pushed in. Haven't had any other clutch issues in the 2 years I've had it.
    Not able to get it to the mechanics until next week and am a little concerned about the size of my bill. Anyone have any reassuring words that this won't be a major fix?
    Jun 2016
    Newcastle
    6
    I had this happen in a Ford Ranger. It turned out the master cylinder was shot (and 2000 kms out of warranty!). Unfortunately for me it was a major expense as the transmission had to be removed to access it. I'm not sure of the setup in the 207, but I hope it's easily accessible and hence cheaper!
    If I were you I'd check the clutch fluid level. If it's down, then the clutch master or slave cylinder is probably the culprit.
    The above probably won't reassure you! Sorry.
    Sent from my F1f using aussiefrogs mobile app
    Jun 2016
    Newcastle
    6
    Check out this thread, if it is the master cylinder access may not be too bad.
    https://www.frenchcarforum.co.uk/for...ic.php?t=48826
    7,031
    The slave cylinder on a 5 speed BE box is accessible too.
    It's the 6 speed manuals that have internal concentric slave cylinders that make a very big job.
    Nov 2017
    4
    Thanks Seasink. I have a 5 speed manual, so maybe that's better news.
    Nov 2017
    4
    Champion, Gunner, thanks. Will check out that thread.
    Sep 2003
    North Parramatta
    3,798
    Clutch slave cylinders are a relatively common (and cheapish) issue on 207s on the UK forums.
    Simon
    2014 208 GTi 2011 DS3 DSport
    2007 207 GTi 2004 206 GTi180 2000 206 GTi 1995 306 XT
    www.peugeotclub.asn.au
    Nov 2017
    4
    Thanks Simon. Starting to feel a little more reassured now.
    A mechanic I initially spoke to said it may mean removing the gearbox, which completely threw me. It did seem excessive.
    Fellow Frogger! N5GTi6's Avatar
    979
    Might come down to the model.
    ML6 on RHR is external slave.
    Justin
    '07 Megane R26
    '07 C3 Exclusive
    '09 308 XSE Touring
    '10 308 Sportium Touring
    1000+ Posts Beano's Avatar
    2,411
    Quote Originally Posted by gunner View Post
    I could replace the master cylinder and bleed the system in some older cars in 30 minutes.
    Doush_504 likes this.
    734
    Quote Originally Posted by Beano View Post
    So what? Some cars have easy access, other hard. I'm sure there are "older" cars with difficult clutch hydraulics too.
    206 GTi 180 - Cat Cams, Remapped Group N ECU, AST Camber Tops & Coilovers, -2deg fixed camber hubs by Frogstomp Racing, 24mm Torsion Bars, AP Racing brakes, Yokohama A050, PeugeotSport Baffled Sump, Powerflex Engine Mounts & Bushings, Setrab Oil cooler, Quaife diff, Velo seats.
    Sandown - 1:31.5
    Winton - 1:45.6
    Phillip Island - 1:58.4
    Previously, 2x 504 Wagon, 505 Wagon, 505 STi, 405.
    Oct 2017
    mallee
    23
    Quote Originally Posted by speaksgeek View Post
    It's bad engineering practice to make such parts difficult to access. You'll find an earlier generation of Peugeot engineers took a more sensible approach and that's what their reputation was based on.
    Beano and Doush_504 like this.
    7,031
    Many (most) modern clutch designas have a concentric slave cylinder, mounted around the gearbox input shaft, so for them it's transmission out. This applies to DS3s for example.
    The 5 speed BE box is an old design, with an external slave operating a lever.
    Oct 2017
    mallee
    23
    Looking up my old time book half an hour was allowed to replace the clutch rod and bush on an early 404 or an hour and a half to dismantle, rebuild, refit and adjust the clutch control mechanism. Now it's a major transmission repair to replace a system that does the same job. Progress?
    7,031
    That was then. I used to do annual decokes as well, and had a hell of a time assembling hypoid diffs.
    Racing and heavy commercial clutches went concentric, and modern car clutches have caught up with them. Fortunately for the OP's pocket, the BE 5 speed box is not a new design, and the slave is external, working a lever and clutch bearing as in the past.
    Oct 2017
    mallee
    23
    But it comes back to the question of why. A cheap, simple and effective mechanism is available with a low repair cost. Why go to a design that will make quick repair impossible and impose greater costs? Apologies for a Luddite intrusion into somebody else's thread.
    Sep 2003
    North Parramatta
    3,798
    Why spend effort discussing a system that's not fitted?
    speaksgeek likes this.
    Simon
    Oct 2017
    mallee
    23
    Indeed. I thought this was a forum on which questions of French automotive design were discussed but I was mistaken.
