Is there 203 Peugeot Mechanic near Ipswich ?
Results 1 to 13 of 13
Like Tree2Likes
  • 2 Post By gilberthenry
Thread: Is there 203 Peugeot Mechanic near Ipswich ?
    Jul 2004
    Castlemaine Area
    499
    Default Is there 203 Peugeot Mechanic near Ipswich ?
    I know a couple that live just out of Ipswich off the Warwick road. They have been into Peugeots and Light 15’s since the 1960’s. When they lived in Brisbane some years ago there was the odd Peugeot mechanic but they say “they are all dying out”.
    They hope to get the ’53 or so 203 re-registered down the track but can only get 2nd gear or whatever. They say the linkages from the gear stick need sorting out or something.
    Some time back the gearstick actually came off in her hand and miraculously a passer by who knew something about Peugeot’s “popped” it back in. I think they have a hose clamp there somewhere.
    They would like to take the car to someone who can fix this and don’t mind paying a fair price.
    I have their phone number if anyone can help.
    The pics below was a few years ago. The D Special is ours.
    John.
    Attached Thumbnails Attached Thumbnails Is there 203 Peugeot Mechanic near Ipswich ?-dspecial-peogeot203-aug11.jpg   Is there 203 Peugeot Mechanic near Ipswich ?-dspecial-peogeot203-aug11.jpg
    8,654
    Ship it to Melbourne and I'll sort it out.
    7,677
    Like this? There's a few ball joints to pop off. Is there 203 Peugeot Mechanic near Ipswich ?-p203.jpg
    Jul 2004
    Castlemaine Area
    499
    Sounds exciting but maybe a bit far for them.
    If it was ours we would already have dragged it down when we moved not long ago from Brisbane to Victoria. There is a 203 man near Bendigo called Ken I think who would know a thing or two ???
    Anyway you are the best reply yet !!!
    John
    Jul 2014
    Gladstone Qld
    50
    Quote Originally Posted by gilberthenry View Post
    John.
    have you tried Maurie est at West Car Sales in Bundaberg. 41527355. They have been Peugeot agents since the 50's.
    graham
    Fellow Frogger! Dano's Avatar
    Apr 2012
    683
    John,
    I'll send you a PM.
    Dano
    Fellow Frogger! Commerciale's Avatar
    Dec 2010
    167
    Interesting - a 203 with French bumpers. If the problem is that the gear lever can't be moved down or up from the second/third plane I suspect that the bell crank lever (2435.05) is frozen onto its support. I had the same difficulty after the car had been sitting for many years. The solution is bringing the support up to red heat followed by a quick quench with water. This is best done with the steering column removed from the car in order to avoid incineration of the whole mess. Lubrication with grease should avoid recurrence. Linkage joints popping out usually result in a floppy gear lever and the inability to select a gear in a particular plane (first/reverse, second/third or overdrive). The cause is wear in the joint's sprung sleeve which holds it on the ball. As a specialty I turn up replacement sleeves with a six mm slot in the side. The alternative is to find unworn ones.
    Jul 2004
    Castlemaine Area
    499
    Quote Originally Posted by Commerciale View Post
    I'll take a copy of this and send it in a letter (snail mail). I don't think Peter has an oxy or gas and he's not all that mechanical but any info is handy.
    Thankyou, John
    Oct 2017
    mallee
    23
    Well worn 203's would get their linkages/gear change/electrical switches in a real mess. Knocked the value off them in the auctions. The worst thing was when the electricals around the wheel would catch fire.
    Jul 2004
    Castlemaine Area
    499
    Quote Originally Posted by Dano View Post
    John,
    I'll send you a PM.
    Dano
    Looks like we might be getting somewhere with some of your replies and messages. We'll see how it goes.
    I'm about to get a French 1913 TH. Schneider up and running so it's all great fun.
    John
    Attached Thumbnails Attached Thumbnails Is there 203 Peugeot Mechanic near Ipswich ?-sch-utc-w.jpg
    DeeCee and Beano like this.
    Oct 2016
    Kuranda, Qld
    19
    Hi. A friend of mine who owns an old 505 like mine recommended Stuart Battersby at Peugeot Tech. I just looked it up, he is in North Brisbane. Ph 3260 7500. good luck. gorgeous old car, love the pics! cheers, Michele
    Jul 2004
    Castlemaine Area
    499
    Quote Originally Posted by Michele View Post
    Thankyou, I will relay this info - - John
    Fellow Frogger! luthier's Avatar
    Northern NSW
    958
    Hey Dano,
    I sent you a PM. Can you call me?
    Dan
