peugeot 307 hdi 2007
Results 1 to 18 of 18
  • 1 Post By melon
Thread: peugeot 307 hdi 2007
    Jun 2016
    12
    Default peugeot 307 hdi 2007
    Hi guys,
    So I have an issue with my engine ecu and possibly the BSi.
    I have purchased a ecu set (ecu, bsi and key) and have tried that (originally without knowing that i need to virginise it).
    Can anyone virginise the Ecu and BSi? or Transfer the data from my current set to the spare set
    I also now have an issue with the klms (my original klms being 67ks ish to now being 220 because i plugged the set in) I wish i didnt plug it in... Is there a way to revert back to the original klms?
    Any help is super appreciated.
    I will be happy to drive to you if you are local or even send it.
    Aug 2016
    Sunshine Coast, QLD
    745
    Hey if the original ECU was the issue you can get it cloned onto the one you just bought there's a guy Mike kn Gumtree in Sydney a few AFers have used successfully.
    1st question what was wrong with the 307 that you replaced the BSI and ECU set?
    Jun 2016
    12
    Quote Originally Posted by dimistyle View Post
    Hey thanks for the reply
    ECU is believed to be dead. error comes up on display and now car can only be started when there is a diag in diag port.
    How would i contact him? I am interested.
    Any idea on how to fix my new mileage issue? loool
    Mar 2011
    Linton.Victoria.
    1,160
    As we have no idea where you are..unless someone does know you...if in Vic....speak to [email protected] SIMS MOTORS BRUNSWICK...got a new "puter"...As my g daughters used to say it.....APPARENTLY CAN CODE KEYS...BEWDY JOE...
    Sent from my HUAWEI TAG-L22 using aussiefrogs mobile app
    1000+ Posts cav91's Avatar
    Sunbury, VIC
    2,228
    Quote Originally Posted by melon View Post
    Unfortunately your kms are now stuck there. They only way to lower is to get a complete ecu kit and instrument cluster from a low km car.
    Sent from my SM-G930F using aussiefrogs mobile app
    406 D8 V6 manual
    Aug 2016
    Sunshine Coast, QLD
    745
    Please view this ad:
    ECU/ECM/PCM/BCU AND ALL AUTOMOTIVE ELECTRONIC REPAIRS,
    http://www.gumtree.com.au/s-ad/south...nt=app_android
    Download the application from the Google Play Store.
    http://goo.gl/7NzhP
    Jun 2016
    12
    Hey Guys,
    Sorry forgot the location.. It's brisbane , qld.
    Thanks for the two options. I will contact them and see what they can do for me.
    From my understanding.
    is that once you virginise your bsi you need a lower k' cluster it wil then take the last saved highest klms (which is mine at 69klms)??
    is that correct?
    Aug 2016
    Sunshine Coast, QLD
    745
    I think youll be stuck with 220km from the cluster it wont go back down to 69km even if you could re program BSI. Its protection to stop odometer fraud. I think there is location in Planet to change the odometer kms under replacement parts if a dealer is to replace the cluster. You'll need the master pin code to write the changes.
    Ps I think Mike only clones ecu not virginises the BSI. You'll have to ask plus you'll need Planet if BSI is virgin not sure why you want to do this if ecu is the problem?
    Just clone your original ecu and should be just plug n play with your original BSI
    1000+ Posts N5GTi6's Avatar
    1,084
    Either way if you clone, or virginise and clone you're now stuck with the higher km's. Like you mention you need the whole set including cluster to lower the km's - that's my understanding from various utube tutorials. At this stage virginising still requires making various solder contacts onto the board.
    Not so sure about there being an option to change the km's in Planet in the BSI. Does this option only show up after the pin code is entered ?
    Scary looking process.
    Justin
    '07 C3 Exclusive
    '10 308 Sportium Touring
    '12 Megane RS265 8:08
    Jun 2016
    12
    Thanks for the replies guys
    At the time i was excited and wanted to try this set thinking it was plug and play...only to read up and find out later that those klms are stuck forever
    I believe the ecu is only at fault, due to the issues i have.
    Yes, I have plannet. It has been useful up until a point. I guess if after it gets going i would need to virignise and get the cluster replaced in order to fix my klms to the correct amount.
    Very scary process lol.
    I would hope that the dealership wont charge to much for that,
    1,084
    I doubt if a dealership would get involved in virginising a board at all. You're really stuck either doing it yourself, or engaging someone pretty game and/or confident to do it for you. I'm not sure this is exactly a PSA sanctioned process.
    Justin
    '07 C3 Exclusive
    Aug 2016
    Sunshine Coast, QLD
    745
    A few guys on Gumtree advertising they can reprogram mileage. Best to ask as BSI needs to be corrected and dash needs to be corrected. Only highest mileage is saved in eeproms. Be specific with your vehicle VIN .
    Instrument cluster Repair digital odometer reset/correction,
    http://www.gumtree.com.au/s-ad/logan...nt=app_android
    Aug 2016
    Sunshine Coast, QLD
    745
    Melon any progress?
    Jun 2016
    12
    Hey guys,
    Was swamped, that week with work and stuff.
    I have tried to get into contact with michael and have started contacting the mileage guy. Hopefully michael will respond/sort out my ecu shortly
    Will keep you guys updated.
    I will also ask the guy in vic.
    thanks guys, melon
    May 2016
    Penrith NSW
    181
    Adjust Peugeot 307 mileage via SVDI PSA Commander
    https://www.youtube.com/watch?v=siyzitWXAJ4
    Aug 2016
    Sunshine Coast, QLD
    745
    Melon any progress over the holiday season?
    Jun 2016
    12
    Okay guys,
    Car got me depressed as it has been ongoing since 2016.
    Got in contact with dimi again through gumtree and we went from there.
    Turns out my ECU was fine and my BSi showed no signs of error (i sent it to testing). It was the TCU the whole time. It caused all the system to be confused and started intermittenly or never. Swapped a TCU from lowood wreckers and she started first time.
    I also had two other errors. A de-pollution fault and an airbag/pre-tensioner issue. The de-pollution fault cleared after driving it around a bit (i also swapped the relay). The airbag light was due to an open circuit fault in the pre-tensioners. Both were replaced and airbag module was replaced. No more faults on the car!!! finally.
    I am no tasked with fixing up the mileage...and re-assembling the car. Hopefully get in contact with michael or the other gumtree advertisement. I believe the easiest method would be to virginise the BSi and source a low klms cluster... hopefully someone can re-program cluster .
    Hopefully this will help someone else
    Edit: oh and thanks everyone for replying commenting, much appreicated
    dimistyle likes this.
    Aug 2016
    Sunshine Coast, QLD
    745
    Well done Melon for closing off the saga. You will have to chase up the guys on gumtree regarding odometer correction as both BSI and cluster will need to be corrected, they both have the same type of IC to be able to read/write the correct kms.
    As far as virginising goes the whole config of the car needs to be inputted again via Diagbox which is a lot of settings that can't just be guessed.
    Almost back on the road now😀
