Dismantling 203/403 lever shocks
Results 1 to 10 of 10
Like Tree3Likes
  • 1 Post By pontarriere
  • 2 Post By tok403
Thread: Dismantling 203/403 lever shocks
    69
    Default Dismantling 203/403 lever shocks
    Does anyone have experience of pulling lever shocks apart? Most of the shocks I have are leaking through the oil seals and I want to replace the seals. The arm that is held on by a nut comes off easily enough (after removing the rubber bush of course), but the other arm is welded on to the shaft that runs through the shock. I thought that this arm and the shaft would come out together, but after considerable pressure with a gear puller on the end of the shaft it has only budged a few millimetres. Are you supposed to grind the weld off this arm and remove it, leaving the shaft in place? Incidentally, the oil seals are 25x47x7 size which are readily available and are a lip seal,much better than the original seals. I have found a good way to clean the shocks is to fill them with kero and work the levers up and down several times. Drain this and repeat a couple of times - a lot of dirty gunk comes out. The oil I use is Penrite shocker oil number 2.
    Dano likes this.
    Fellow Frogger! PCOATES505's Avatar
    Jun 2002
    Gunbower
    355
    grinding the welds off then removing the arm is the only option, unless you have some special tools to support the finger that moves the piston. pressing the shaft to remove it will result in the finger breaking the piston unless the bearing inside the arm is supported. cheers Pete
    PS when you get the arm off you usually find the old seal has worn a big groove in the arm, this will require either welding and machining or a speedi sleeve
    I am gunna get another 403 on the road........one day
    Oct 2017
    mallee
    23
    Does any firm offer a reconditioning service for the lever arm shocks?
    bob
    bob is offline
    May 2001
    Skipton
    2,012
    Default in olden times.....
    G'day,
    these things were the cause of some grief in my youth - Morris products in those days, but as I recall Austins were the same, in the era before amalgamation..... maybe.... which suggested that the OEM thing was all the same.
    Never pulled them apart, can't help there. They were invariably all different in their action, used to hang a spring balance off the end of the arm to check 'em - or was it a bloody great weight and stopwatch - or was it elbow feel - it was a long time ago fellas....
    To even out the hydraulics I used to go the motorbike shop and get a selection of fork oil grades. Corrected and improved the handling on a number of these ancient beasts, the before and after driving experience was always quite marked...
    cheers,
    Bob
    Oct 2017
    mallee
    23
    You could buy reconditioning kits for the shock absorbers. We used to get a local engineer to do them. It wasn't cheap. You could send them away to places that offered a reco service. People short on money would put heavier oil in them. They were told not to do it because the arms became prone to breakage. The biggest problem was chopping out the bush where it met the front assembly. They used to send up Australian made bushes that didn't last. If you specified French it lasted longer.
    1000+ Posts driven's Avatar
    Apr 2005
    1,024
    Bush Mechanic again
    Brake fluid will swell seals. May stop the leak. A tiny amount for a shock
    No warranty on this tip
    Member tok403's Avatar
    Oct 2017
    Sapphire Beach
    52
    Made me reminisce on a different mode thinking about shocks
    https://youtu.be/bx0rwtVDi1I
    NOW: 1960 403 Sedan 1953 203 Ute Honda vfr800
    Previous Peugeot 1 203 6+ 403 7+ 404. 4 504 4 505. 1 205
    Renault. 3. 12ís. 2. 16ís 1. 25wagon. 1. Floride
    Citroen 1gs
    Mar 2011
    Linton.Victoria.
    1,118
    I did a set about 12 ,years ago....took them to engineer mate...dangerous job on lathe...machined bore...fitted New seals...no prob...I have heard of people being charged 2 to 300 bucks EACH...,for them being repaired by complete thieves...in my opinion...amazingly they were happy to pay...lost me...
    Sent from my HUAWEI TAG-L22 using aussiefrogs mobile app
    Oct 2017
    Sapphire Beach
    52
    Here is great site on rebuild can’t translate but picture paints thousand words.
    http://sd-2.archive-host.com/membres..._203part12.pdf
    friday403 and Roland like this.
    Citroen 1gs
    69
    Thanks tok403 - that link is fantastic. I spoke to Malcolm Goodwin at Cessnock who is a 403 expert - he told me you have to take the round caps off the bottom and remove the pistons to get the other arm out (as shown in your link). The second arm stays welded to the shaft.
