404 rubbers info required
    Member Mitchell's Avatar
    Perth
    99
    Default 404 rubbers info required
    I'm having a hard time finding a supplier for the rubber seals between the front guard & the body on my 404 wagon.
    The seal in question can be seen inside the front wheel arche curving up to the inside profile of the guard itself. There is also a smaller bit under the front edge - between guard & engine bay.
    It's no longer available from Peugeot and I have no sample to source a similar item.
    Anyone know an alternative supplier and part number?
    Thanks & regards,
    Rhys Mitchell
    303
    Try www.scottsoldautorubber.com.au
    They have a page for the 404 but your part is not listed. But you can download their catalog and you may find something to suit.
    Good luck
    Jarrod
    12,264
    do you guys have a clark rubber over there in the sunset state ?
    if so go and see them and go through the stock of rubber they have and see what you can get that goes close
    i have used clark rubber quite a few times over the years with good results
    1 x 2018 3008
    1 x 2000 Citroen XM,
    1 x '98 306 GTi6 sadly sold
    Perth
    99
    Thanks for the feedback.
    Scott's unfortunatly do not list these rubbers (had already tried them).
    Yes, Clark Rubber does exist in WA(and is good for rubber stuff), but I don't have a sample of the profile to match up.
