Air COnd TX Valve replacement on a 407
Results 1 to 7 of 7
Like Tree2Likes
  • 1 Post By seasink
  • 1 Post By seasink
Thread: Air COnd TX Valve replacement on a 407
    Oct 2014
    Brisbane/Australia
    326
    Default Air COnd TX Valve replacement on a 407
    I have been advised to replace the Thermal Expansion (TX) Valve on our 2007 407 Sedan to improve the cooling of our air cond system.
    Has anyone done this before? WHat is involved? Any instructions on how to do this? or is it a job for a specialist?
    1000+ Posts cav91's Avatar
    Kyneton, VIC
    2,174
    Probably not a whole lot of help but on a 307 it's about a 15 minute job. I think 407s where similar in design. Were the tx valve is were the a.c. pipes go through the firewall.
    Sent from my SM-G930F using aussiefrogs mobile app
    406 D8 V6 manual
    7,342
    The handbooks call it a Détendeur, and it's at the bulkhead beyond the high and low pressure valves. You will need a refrigerant licence.
    Roland likes this.
    Oct 2014
    Brisbane/Australia
    326
    oh, ok. So I should have an air cond person do it. Thanks for that.
    7,342
    It's a metal block, with passages so that both the high and low pressure circuits pass through it. Inside are small passages fitted with a regulating valve. Removing it means disconnecting the refrigerant pipes, so take it to someone with the gear and the gas.
    Roland likes this.
    7,342
    There's a pic in this ad - https://www.24piecesauto.fr/climatis...on/peugeot/407
    It's a small but high precision bit of gear.
    I found a sectioned drawing of a Ford unit: Air COnd TX Valve replacement on a 407-screenshot-2.jpg
    17,150
    Unless you are sure that you can complete the task, leave it to an expert.
    Technically, you are required to have a refrigerant handlers license to de- pressurise the aircon system.
    It's usual to replace the filter dryer whenever opening the the refrigeration system.
    Do you have a vacuum pump, manifold gauges, refrigerant scales and a supply of refrigerant (probably R134a) to re-charge the system?
    Mutual Respect is Contagious
